Old 12-24-2003, 03:13 PM   #2101
Suspended
Default SERPENT 710
WINNING CIRCLE HAS SOME 710'S LEFT www.gasrccar.com choco
kenchoco is offline   Reply With Quote
Old 12-24-2003, 04:53 PM   #2102
Default Re: Re: Re: Re: Re: Re: Steering Linkage Pic 2
Originally posted by Schrijver99
:so the shocks moves a little better
If what you mean is making enough clearance, so you can turn left and right (when mounted) more than the stock balls can do.. Im agree with you. You got the point !!
This thing is defenetely the snakes should upgrades not straight or slanted position.
And most of broken shock shaft is begin with this tight clearance condition.
Julius, if we may suggest pls reduce the thickness of top pivot shock mounting (in flat ball position). So there is enough room for the shocks to move more freely when the wheel / arm impacted real hard.
Actually in my 710, lower bumper plate is cut in two!(whoa!!) just found it last night. But that was it... nothing else happen, even the top plate is still holds the droop screw precisely.
...And it doesnt broke the shock shaft.
I think this time the snakes did their homework quite well, handling wise...there is still so much thing to discover.
GoldFinger is offline   Reply With Quote
Old 12-24-2003, 07:05 PM   #2103
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Default Re: Where can I find one?
Originally posted by Impulse_racer
My girlfreind just called me and said she was getting a 710 for me for Christmas but has not found one after two days of calling all over. Does anyone know where I can order one? Thanks in advance.
Cruizin with RC's...Ramsey NJ..201 825 4884
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 12-24-2003, 07:30 PM   #2104
InitialD's Avatar
Originally posted by evlhdlts
hey you guys who got your snakes already.... does the kit come with a battery pack??? if not, where did you get yours and what's the best deal out there??
The kit does not come with one. You need to get them made with 5 x AAA batteries.
We get ours here spot welded and shink wrapped with connectors with 800 mAH Sanyo ones at about USD 15 !
In any case, whatever you do, don't stinge on the receiver pack. Have them made properly and professionally if it's possible.
Old 12-24-2003, 08:28 PM   #2105
Moderator
Jpilone's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Jpilone
These kits are in stock and are $359.99 at Fast 'n' Furious R/C!
http//www.fastnfurious-rc.com
-Jarrod Pilone
Pro R/C Photographer
http://www.jpsportspics.com
Jpilone is offline   Reply With Quote
Old 12-24-2003, 09:20 PM   #2106
Default MERRY CHRISTMAS
To all here at the 710 thread have a joyous Christmas
Hope Santa brings you what you wanted, like a 710
I wish it would snow here
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 12-24-2003, 09:39 PM   #2107
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Default Re: MERRY CHRISTMAS
Funny u said that,..Santa did bring me the Serpent 710 on my lap...i was the 1st one to touch it & open the box from the LHS owner.....but but it came with a price tag
I will be the 1st one AND THAT SCARED ME!!
Merry Christmas to all snake guys out there. i hope i will shed out my skin too when i decided to get it.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 12-24-2003, 09:47 PM   #2108
InitialD's Avatar
Did Santa bring you a 710?
Old 12-24-2003, 09:52 PM   #2109
Default Re: Re: MERRY CHRISTMAS
Won't be able to make it for Christmas Probaly next year in Janurary I hope
Got the 705 conversion for my Impulse. Too bad no ti chassis for the 705
BTW, isn't Christmas there already. Its like 7:30 pm Christmas eve here. Any way best wishes to you and your family, Merry Christmas
Old 12-24-2003, 11:51 PM   #2110
The Brown Santa said he's going to be late ... he said to expect him with my present Tuesday or Wednesday.
nad138 is offline   Reply With Quote
Old 12-25-2003, 01:26 AM   #2111
Derby Bros Racing's Avatar
where did you get exactly the $15 packs?
thanks in advance...
Derby Bros Racing is offline   Reply With Quote
Old 12-25-2003, 02:04 AM   #2112
S710_Nut's Avatar
"Santa bought me my 710!"
S710_Nut is offline   Reply With Quote
Old 12-25-2003, 03:08 AM   #2113
Julius's Avatar
True. But I think not just that needs to be achieved. The steering left and right must not be binding too.
The reason why the shim of 0.5 mm was introduced was because it seemed like the link could rub on the front belt at certain steering positions.
Secondly, when turning right (servo horn pulls backwards towards the tank / clockwise), the linkage ballcup can bind against the servo arm at the furthermost end point of the servo. Shortening the linkage rod and the ballcups enables the servo arm to be moved forward and when the servo arm moves towards the tank to make the right steering, the ballcups will not be at the end position where it will rub against the servo arm.
But doesn't the shim actually bring the link closer to the belt? I did cut a little of the inside of the nylon ballcup to clear the arm at full right steering.
Julius is offline   Reply With Quote
Old 12-25-2003, 03:27 AM   #2114
S710_Nut's Avatar
Guys,
I have just been reading the setup book that comes with the kit, it gives alot of great information, Just confused on the rear roll centre adjustments, the book gives adjustment for Longer Upper Arm and Shorter Upper Arm?
Old 12-25-2003, 03:43 AM   #2115
Diesel Racer's Avatar
Default Hudy Tyre Truer
Santa bought me a lovely Hudy "Power" Tyre Truer.
Thankyou Santa
I'm going Foam racing, Yehaaaaaaaaa!
Diesel Racer is offline   Reply With Quote
