Serpent 710
Old 04-01-2005 | 05:25 PM
  #20821
Darth Vader's Avatar
Default Rear tyre coning
Thanks for the tips guys.
I'll try setting the camber to get the right tyre coming instead of following equal left/right values.
Darth Vader is offline
Old 04-01-2005 | 05:28 PM
  #20822
Originally posted by Julius
No, I prefer the Mazda over the stratus2.1 I do think many would be better off using the Stratus as it is easier to setup and race. The Mazda is slightly faster though.
The alfa is a Losi. It was painted by Maarten Pothuizen for the euro's last year. I haven't run it yet, but RickV used it at Heemstede and was really fast. So I finally took the time to mount it for a testdrive....
I prefer the wing design on the Losi body. The one that comes with the Protoform bodyshell looks very simple. Donno which works better though.
Didn't see any cooling/refuelling cut-outs on the shell.
Is this a show-shell?
Old 04-01-2005 | 05:52 PM
  #20823
JustRace's Avatar
Well I didn't do anything exept cut and sticker.
But the dots can be made by spraying a bit of silver in a jar. Then using a very small brush put the dots on the windowframe. Them back it with black.
How about sending me that body so I can take a closer look
JustRace is offline
Old 04-01-2005 | 06:10 PM
  #20824
Originally posted by Greg M
Frewer only recently got their web site up and running.
Coming from 1/8 I wanted to run solid rear and one way front. Haven't tried it yet, so will be interested in the results.
Hi Greg and Redsand (where are you bro? )
1way front + rear solid you can expect fastest cornering.
With a BIG but, very much unpredictable maybe its me. Even in very high traction condition. Even with softest rear setting + 3.0 rear toe-in.
Only 1 driver (at least I ever saw it myself) who using it, Master Suruth in Srinakarin. But he was using Alfa Romeo 2.0 shell with sky-high rear wing, so i realize that he is dying for rear traction too.
For me, the setup is sacrificing (??) others section too much.
GoldFinger is offline
Old 04-01-2005 | 06:34 PM
  #20825
Greg M's Avatar
Rear tyre width would be the problem
Greg M is offline
Old 04-01-2005 | 11:40 PM
  #20826
redsand's Avatar
Default Re: Re: Re: Re: Re: Re: 710 Lola Shell Pics
Originally posted by Pyramid
Serpent MRC do not make one but I think Hobbylink Singp has it custom made. If you want I can pass mine to you to try.. r u coming to Nats1?
I thought I'd seen one that Serpent was planning to produce. It was on the .pdf file from one of Serpent distributors in Europe. But I'm might be mistaken.
Do you have the pic of the one that was custom made by Hobbylink Sing by any chance ?
About the nats #1, there have been few things that prevent me from racing out of town. So, I'm kinda like a master of my own domain
redsand is offline
Old 04-01-2005 | 11:47 PM
  #20827
redsand's Avatar
Hello bro what's happenin ?
I think a solid rear has much less rotating mass compared to the standard diff. Have you noticed anything from it while running a solid rear ?
BTW, what rear tire width do yo run with lola ?
redsand is offline
Old 04-02-2005 | 12:56 AM
  #20828
Julius's Avatar
Nope not finished yet. The pics look better without the holes....
Julius is offline
Old 04-02-2005 | 01:45 AM
  #20829
Pyramid's Avatar
Registered User
Default Re: Re: Re: Re: Re: Re: Re: 710 Lola Shell Pics
They are with Goldfinger at the moment.. I`ll ask him to sent to you next week...
Pyramid is offline
Old 04-02-2005 | 01:58 AM
  #20830
Just Race,
You have been painting some real cool bodies. Are you going to hook me up for the next race. Let me know.
www.twistertires.com
racinghobbies is offline
Old 04-02-2005 | 06:04 AM
  #20831
JustRace's Avatar
Originally posted by racinghobbies
Just Race,
Racinghobbies..Nope!!!....I'm trying to get hooked up myself. Hoping Julius will send me a body I told you to run on VRC. No bodies to paint, no motor to breakin, no dirt under the nails.
Maybe Jag will paint you a body
JustRace is offline
Old 04-03-2005 | 11:44 AM
  #20832
Pandora's Box's Avatar
Default Flyweights mod
Guys,
Putting together my latest babe, a 710. It's been ages since I had my hands on a serpent. Now this is what I call a racing breed!!
I was reading through previous pages on this thread to see what the 710 gurus were doing and came upon this...
1) What's the reason for cutting the flyweights and and then putting it between the pins on the flywheel?
2) What are the benefits?
3) What's wrong with the original design of it attached to the pin?
Anyways, it seems like we are going backwards to how the original centax1 was designed....free floating weights(with circular spring attached).
Ceramic ball for diff necessary? Seems llike the huge steel balls will last some what (comparing it to my EP car - ceramic balls are a huge advantage).
Cheers!
Pandora's Box is offline
Old 04-03-2005 | 12:52 PM
  #20833
border r/c's Avatar
He Julius you watch to much Mylaps
catch you later
border r/c is offline
Old 04-03-2005 | 01:13 PM
  #20834
Julius's Avatar
catch you later
Actually it was worse.... I was there to watch....
Julius is offline
Old 04-03-2005 | 02:44 PM
  #20835
RickV was blinding fast, half a second every round? 2 laps front in a 20 min main? (or was it 30 min?)
That's amazing
_cyclops_ is offline
