Serpent 710
Originally Posted by Julius
Ah, yes the picture of the Merc....
Did you see the pic of the wheel on the other side???? Indeed other way round installed it was
Originally Posted by markp27
You know, I'm getting the distinct feeling that D and myself wasted our times looking for the Ring in far off lands......seems someone else has had the Ring the whole time
Originally Posted by Rene C.
The Serpent universals are nor the same than the universals from 3Racing.
You guys are right, they look nearly the same, but they are not.
That, just to clarify before a big rumour gets started.
See you guy’s
Rene
See you guy’s
Rene
Very glad to hear the truth !
Thanks Rene.
Originally Posted by RMeira
But are the 3Racing universal one's good parts ???
guys if the serpent universals are already available what is the part number please,thanks
Not all third party products are bad.
The CVD's may not be as good as the serpent ones, but the 3racing carbon/graphite parts are easily as good as the original parts. I broke my radio plate (don't ask) and replaced it with a cheaper 3racing part. It fits perfectly, and in fact looks a little bit better than serpent's part.
Originally Posted by Pyramid
thank you very much Pyramid
Hi Everyone,
Finally got a chance to run with the 21T option pulley and the car was absolutely dialed. I also achieved excellent wear rates using 40sh front and 37sh rear. One other thing I changed was using the front ball diff, so far I have broken two friction rings because I did it up to tight (Rene please design a aluminium part). To counter this problem I had the 3racing friction collar that i tried on the rear diff and didn't like it because I found it didn't improve the car. So i put it on the front and used the dremel to make it the same size as the diff pulley (required only if using the optional servo saver).
I don't see me changing back to the oneway as I had no perceptable loss of off power steering and gained improved and consistent braking. I should also mention I'm using the race brake pad set and vented brake disc.
Originally Posted by B4
Hi Everyone,
I saw Richard Keur (dutch driver) drive with a allow clamp, micht be 3racing but i don't know.. he is a serpent team racer, so i gues it's comming....
Hi Everyone,
To be honest, it is already done. I used it a long time, to find out the right material, also Kolff and Keur used it. Both where happy with the result.
You wish it, we do it.
Rene
