Old 04-03-2005, 10:22 PM   #20851
redsand's Avatar
Send a message via Yahoo to redsand
Default Re: Re: Re: Re: Re: Re: Re: Re: 710 Lola Shell Pics
Originally posted by Pyramid
They are with Goldfinger at the moment.. I`ll ask him to sent to you next week...
roger that. thanks.
redsand is offline   Reply With Quote
Old 04-03-2005, 10:59 PM   #20852
Pandora's Box's Avatar
The trick is to use the Mugen Super Grease on the diff balls (as well as the Centax thrust bearings). I find other types of grease is not sticky enough and they fly out very quickly after a few rounds. Put some grease on a paper towel and smear it evenly together with the diff balls. I actually ran the same diff balls and plates for close to a year without any gritty feeling in the diffs. I've very seldom taken the rear ball diff out to service and clean it. Only went to ceramic balls diffs because I was itchy.
Instead of the Mugen Super Grease, will the Team Associated Stealth Diff Lube work? Have been using that for my other diffs with good results.
Is the Mugen Grease really that "Super"?
Pandora's Box is offline   Reply With Quote
Old 04-03-2005, 11:17 PM   #20853
InitialD's Avatar
The stealth lube works but they don't last for long. After a few runs the diff will be dry and then if you're not careful, they turn gritty. While with the Mugen Super Grease, it sticks pretty well even after a few races. No need to dissassemble to clean and maintain.
Try putting a light coat of this grease on the polished side of the diff axle before putting on the diff collar. It makes the setting of the diff collar better and more predictable.
Well, that's the only thing that is "super" about the *spit* product.
Old 04-03-2005, 11:24 PM   #20854
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by JustRace
Sounds bad Bent chassis, radio tray and fuel tank?? Kinda late but I wonder if a throttle return spring would have helped.
Definately - Rene was kicking my arse for half an hour for not having one
Better would have been a spring to pull the brakes on, though - it must have broken towards the end of the straight, as I would have noticed otherwise that the steering wasnt't working anymore. So shutting down the throttle would only have lessened the severity, but perhaps a auto-brake would have saved it.
Don't understand why the fail-safe didn't cut in on the servo, though
markp27 is offline   Reply With Quote
Old 04-03-2005, 11:26 PM   #20855
markp27's Avatar
Originally posted by rwisejr
Man hate to here that. That is a bad break !!!!! Thats why I like my synthesized and If this spektrum works out stuff like that is all but eliminated.
I was too mean to pay the currently high price (in Europe) for the Spektrum, but now it may have cost more than what I'll save later.
Old 04-03-2005, 11:30 PM   #20856
markp27's Avatar
Originally posted by InitialD
Fire the pit guy.
Even Rene said it was probably a bad idea that I was running the Mölzer-Mowery shell from the Winternats
Congrats... A new pit monkey?
He needs to work on his running a bit - with my driving style, I need a pit monkey who can sprint like a world class althelete
Old 04-03-2005, 11:31 PM   #20857
InitialD's Avatar
Strange... Are you sure the fail safe is set to on in the first place?
The fail safe would not have worked if there was no power from the receiver pack.
Old 04-03-2005, 11:32 PM   #20858
markp27's Avatar
Hey, sorry to hear that. Like what JustRace mentioned, I think if the TRS would have been used, it would have saved the situation. Kinda sucks that the crystal broke on the straights...
And it hit the only solid thing on the whole circuit - the rest of the circuit is surrounded by grass banking and catch netting Real murphy.....and why the fail safe didn't kick in - no idea!
Old 04-03-2005, 11:34 PM   #20859
InitialD's Avatar
Even Rene said it was probably a bad idea that I was running the Mölzer-Mowrey shell from the Winternats
That must probably be it. Jinxed !
So that will definitely rule your bro out then.
Old 04-03-2005, 11:36 PM   #20860
Old 04-03-2005, 11:37 PM   #20861
markp27's Avatar
Fail safe defintately works, it cut in last week when my receiver pack voltage went too low.
Rene thought the power lead had come out first of all, but when I got back to the pits, I found that my crystal was dead.
Old 04-03-2005, 11:40 PM   #20862
markp27's Avatar
Better get Fredrik's opinion about this one
I've put him on a diet on training plan already, so he'll be fit for Sept, when I take part in the Snetterton round of the UK championship
Old 04-03-2005, 11:46 PM   #20863
InitialD's Avatar
I can't wait to see this slim version of your bro.
Old 04-03-2005, 11:48 PM   #20864
InitialD's Avatar
Perhaps that crash was bad enough to damage your crystal. So it may have appeared that your crystal died before the crash...
Just test it out. While the Tx and Rx is switched on and connected to the servos, unplug the crystal... I'm pretty sure it'll go into fail safe mode.
Old 04-03-2005, 11:49 PM   #20865
InitialD's Avatar
Don't laugh out too loud... The God's are hearing and before you know it, you probably be hunting for it high or low.
