Mugen MBX6
Hey guys I am running the 6r and I need to settle the rear down just a little bit. On acceleration it can be just a little loose and squirley. This is the setup I have in it now just stock:
http://mugenseiki.com/images/mbx6r/s..._us1103kit.pdf
I do plan on getting the BCE x3 chassis soon, but for this weekend what would be the best fox with this +5 stock chassis?
I tried 8.25 front and rear and the car was hard too drive. I went with a softer rear spring and it was good.
guys, can someone please explain how the mugen springs work, ie the numbers in relation to springrate im confused. seems the number is actually the number of turns and a higher number is actually a sogter spring? the mugen chart is a bit confusing, especially when reading the above post alluding to the fact that if one goes down from 8.25 by 0.25 or 0.5 one should end up with a 8.0 or 7.75, which the mugen chart seems to say is actually a harder spring
Thanks, im used to color coded spring charts ;-)
off the topic....mugen hex hardware is metric or standard? losi is standard I need to know if I have to look for a hex tool set
Just orderd a BCE X3 chassis from Bill and I still haven't started the build yet
8.5 front and 8.75 rear are just just announced but I don't know when they'll be in the shop. Until now, 8.25f and 8.5r are the softest springs available.
on my xray i just went one harder in front and my car was nice on most of our tracks
Yep indeed. Most shops have the new springs already, except amain hobbies. I don't know if I'll buy them. Our cup has only 1 dirt track and it's medium traction but bumpy in some spots. The other tracks are astroturf. But they might come in handy when the track is wet.
All you guys who ordered the BCE 3mm will love them, it will give you back ever thing you lost with the 5mm but still good in the rough. Along with the truggy tower,front batt and rear Kyosho springs the car is very good. Here is our setup again with the chassis,tower etc .. Donnie
Adding to what the others have said you can also lower your camber link in the rear tower and lower the rear shock one hole on the tower also something we did with the 5mm to help is to raise the ft end higher then the rear. It's an easy try and it seemed to plant the rear more and still keep your steering. But the only way to fix it all is to shorten the chassis.
I'd really like to do some back to back testing in the morning on an astroturf circuit when it's still a little damp with BCE x3 and the stock +5mm chassis. Unfortunately my wallet is too small to buy a new chassis just for testing
Donrod, I'm wondering what's the difference is between the 5mm with medium wheelbase in the rear and 3mm chassis with the long wheelbase. The wheelbase should be same, just rear sticking out 2mm more with the 5mm chassis.
Yea, I know. 2mm isn't a lot, but I have no clue how that would translate into car handling.
