Mugen MBX6
#3857
Is it a major issues if your linkage does hit the tank when on full throttle?
#3858
It can be, if it's too much pressure it could cook your servo or wear a leak into the tank, depends on the carb's throw I guess. Unless you tune your brakes frequently I don't think you'll be too bothered by it, the links turn pretty easily in the blocks on the servo horn.
#3859
#3860
hi boys.does anyone have the mbx6 skins in electronic form?
if not,does anyone how can i create one?i have the blue ones.
thanks!
thanks!
#3861
So is there any easy way to keep the linkage from hitting the tank? Seems like everytime i get it right, it will hit the tank and then i have to back it off some (loose brake) to get it to stop.
#3862
try doing a search if i remember correctly there is a post somwhere that tells exactly how to set up the stock tb linkage
#3863
#3865
The key is the angle of the rods off the servo horn. If this is correct the rods pass through sort of a window just bast the back of the tank. You could cut them down to minimal length but you may run into throw difficulties if you change to an engine that has a narrower carburator. For instance, OS's are really wide, Sirio/Star/Werks are really narrow. Changing between them caused me to have to re-adjust my throttle linkage a fair amount to accomodte the difference.
#3866
I don't know how that got past their R&D team. It has given me fits on a consistant basis. I end up getting it right. But surely there could have been a better design. Well, maybe not now that i think about it. Seems like mugen fit so much into the center of gravity something had to give. I am ordering the pro linkage set. Maybe mugen could copy it
#3867
Nothing about the linkage setup got past the Mugen guys, there's a right way to set it up and if it's right, everything clears/fits, just depends on the servo horn and having the links at the right angle so they move into the space that they're intended to go into. If you use the Dynamite linkage it is a little easier to adjust and nothing hits the tank but you will very likely have to cut a hole or slot into the body because the fuel tubing and knobs are now outside the servo horn. This also leaves them vulnerable to being hit by other cars. It works well, but it's not without a downside.
#3869
The most important parts of the update are lighter springs and swaybars, those are the only things that actually make a difference in how the car runs in the updated kit. It also has small updates to some of the parts. The front arms have reliefs molded into them for the longest travel settings, the rear upper hinge pin mount is stronger, the radio box has a taller battery lid.
I have the 1st gen kit and I've only done the springs/swaybars. I have an M2C upper pin mount somewhere but I've lost it. Hopefully I don't need it before I find it again.
#3870
LOL! loosin stuff sucks... over all i dont know if you guys ever drove a losi but what could you say are the major handeling characteristics of the mugen compared to the 8ight?
i thought it felt less twitchy but seemed to needed to be driven smoother thne the losi car...i only drove my buddys mugen for about a tank but i really liked it..plus its a pretty bad ass ride
