World GT-R Rules and Discussion
#1831
My tires have arrived so I've started working on converting my car from wgt to wgtr. The car is a Serpent S100-LT. I was able to get the rear ride height to 5.6mm using the 0/40 axle inserts. I'll use spacers under the bulkheads to fine tune ride height.
I used 5mm spacers up front to get the ride height down to 5.2mm.
I mounted up the tires and test fitted my old mx stang to find the the front tires stick out slightly. Looks as though the S100LT runs wide up front. I test fitted a 200mm hpi R34 Skyline body and it just fits. With that said, it looks like I'm stuck using a 200mm body. What are some good options for 200mm bodies for black crc FT2 carpet?
Also, what sort of setup changes should I be looking at when converting from wgt to wgtr?
#1833
Do you attribute this to the fact that the 'better' bodies require narrowing the car or do you think there is something inherently better about running the car under the legal max width?
#1834
We just haven't found a way to make them quick at full width yet. As soon as someone does........
Keep in mind that 235mm pan cars have tons of aero in the body, while in WGTR, the body is mostly a hindrance.
#1835
Machined some 4.25mm brass spacers for the front. Will slot some holes so that I can reduce the front width.
thank you for the help and suggestions so far!
#1836
Slotted some holes and got the front track width down to 196.5mm from the outsides of the sidewalls. MX Stang body fits now.
#1839
Locally, all versions of the CRC car have proven fragile. Most guys that have tried them have moved on due to frequent front end breakage. I bet dollars to donuts that if you walked our track right now, you could find at least 1 broken king pin and one of those little white spring retainers.. If I recall, some racers also had issues yanking the side links off the chassis (pivot ball screw ripped out of chassis)
Most of our local WGT-R racers now run the Xray X10. The front end is bullet proof and euro style ball diff(w/ thrust race) is actually usable on black carpet.
#1840
You can run Roche, Xray, Speedmerchant, Reflex, Kawada, any old WGT car that can have the rear axle spaced up enough.
#1841
It seems like CRC is the only company that puts factory level talent in the WGT-R class. In my opinion, this is why all the big races seem to go to CRC in this class.
#1842
Looking through my stash of bodies, I came across a hpi ford gt 7495. Wouldn't you know, it's actually on the list! It weighs 101g unpainted.
I also have a hpi McLaren f1 body. Such a cool lookinglooking bummer that it isn't on the list.
#1844
With the rubber tires pretty much any chassis can be competitive I've seen a old associated 10L come out and be a top 3 car. And as for the CRC is fragile comment all cars break some more then others. And for you to compare crc to xray. Hell u can put xray up against any manufacturer and there parts are far more durable and 3 times the price. There both great cars for the class CRC just does it at a fraction of the price.
#1845
I find this odd. I have zero issues with the durability of the CRC cars (I run both the GenX10RT and CK25). This also goes for many of our other local racers here. I am on season 3 with my WGTR car without a single broken part. I am not a bad driver, but I am not a great driver either, and the car still treats me well. It has been incredibly consistent for me, and I would recommend the CRC to anyone wanting to get into WGTR.
