New Novak Brusless System
#511
I've had a few minor issues running a ss5800 with a JR xs-3.
But it was quickly rectified by checking my antenna length and making sure the aerial staying up in the antenna tube.
I got a distinct dead spot (about 15-20m away). throttle delayed by a second and some small steering deflections. But just mainly the throttle hesitation.
I've heard other ppl with issues with JR recievers and the 5.5R
#512
I'm building a RC10 FT TC4 with a SS+ 5800 Brushless. My Spur gear is a 100T 64P instead of the factory 72T 48P spur gear. Now the directions say use a 25T 48P Pinion with a 12-Turn Modified so I'm thinking that a 35T 64P Pinion with the 100T 64P Spur would just about be the same gearing. Am I close?
Rick
Rick
#513
smoking!
A little advice to all who have brushless speed controllers,I wrecked my car today (schumacher mi-2) and hit the controller case,which split and caused the pin connectors inside the case to rip free from the lower board and cause a spectactular melt down. It burned like phosphorous untill I could get the battery leads cut (soldered battery).The moral of this story is try to position the speed controller in a area where it CANNOT get hit during a crash and this will not happen to you.
#514
Super Moderator
#515
Super Moderator
Here is mine with the GTB
(sorry for the bad pic is from my camera phone)
#516
To whoever asked. The Neo 3-Star is equivalent to the Novak 6.5. The Neo 4-Star should be competitive with the Novak 5.5.
I see that on the Neo 1-Star, there are numbers on the can beside the wire tabs. Would anyone by chance know what these are for?
#517
Note to LRP:
Just fricken name 'em by the wind. 5.5, 7.5 etc. Jeez.
#518
Novak SPortsman settings
For those who have used the Novak in its "Sportsman" setting, how close is it to a 27t motor?
#519
Think of it this way. If you were running a a marathon bare naked and someone was behind you whipping your a** you would tend to leap forward a little then ease up to your original pace.
#520
Rather than setting the ESC on a limited setting, wouldnt it work the same if you adjust your radio setting so that instead of having 100% forward movement on the throttle you set it to 50%, 60% or 70%, etc....?
#521
Team duratrax, and vadn1,
Thanx 4 your input, i was only thinking of it as a practice tool for stock racing, saving all that motor maintenence, but your points are valid and definately noted!!
Thankx again!
Thankx again!
#522
The limited mode as others have said, only limits max rpm.
Otherwise, it's not really comparable to a stock motor at all! Actually, it's not really even equal to a 19t.
The ss5800 has some pretty mumbo rip. It will accelerate like a mod motor then top out at the limited rpm. Some ppl think a 19t in good tune is faster than a 5800 in limited mode but i haven't seen it.
So.. in conclusion:
5800 in limited mode - MUCH faster than a stocker
On par with a 19t but has more acceleration and torque
Hope that helps!
(i loved mine so much i bought a GTB!)
So.. in conclusion:
Hope that helps!
#523
#524
WHO LET THE SMOKE OUT !!!
Originally Posted by axle182
PICS PICS PICS PICS!
#525
Nice Tim!!! I think its because it was in a SCHUMACHER!!! Just Kidding
