New Novak Brusless System >
Old 03-06-2007, 08:51 PM
  #2011
rcdy's Avatar
is novak going to produce brushless motors equivalent to 23t? i've heard that the 13.5 is not a stock27t but rather between 23 to 25 turns.
rcdy is offline
Old 03-07-2007, 03:15 PM
  #2012
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
When will the new SS systems hit the hobby store shelves?
HVFracingwilly is offline
Old 03-07-2007, 03:30 PM
  #2013
Davidka's Avatar
Trader Rating: 86 (100%+)
The challenge is in making a brushless motor "bad enough" to mimic a stock motor. They closely approximated the wattage output of a 27t stock but a brushed motor has brush drag and the efficiency drops with heat and the performance fades. Because the B/L motors are so much more efficient you don't dump the battery as far into the discharge/voltage curve either. From 2-3 minutes on a stock motor's performance drops in a way that an equivalent B/L never would. The answer is to abandon brushed stock all together. Brushless motors are much more difficult to tamper with and the performance is far more consistent from one to the next. This is way more "stock" than brushed stock ever was.
Davidka is offline
Old 03-12-2007, 05:59 AM
  #2014
RocketRacer's Avatar
my new system. i am looking forward to installing this in my 415MSXX.
RocketRacer is offline
Old 03-12-2007, 07:05 AM
  #2015
kamikaze's Avatar
kamikaze is offline
Old 03-12-2007, 08:16 AM
  #2016
Default Brushed Mode
I am racing both Brushless and Brushed but was thinking of using the same speedo for both.
Has anyone found any difference between using a "conventional" brushed speedo (such as a KO VFS) and the Novak GBT in brushed mode?
stuartb is offline
Old 03-12-2007, 08:26 AM
  #2017
syndr0me's Avatar
Trader Rating: 32 (100%+)
Novak says the GTB is their best brushed speed control. I guess it's got even better stats in brushed mode than the GTX.
syndr0me is offline
Old 03-12-2007, 04:51 PM
  #2018
JayBee's Avatar
Trader Rating: 31 (100%+)
I was told today by Novak that sometime around mid-April. Did you know that the new 13.5 SS Pro version motors are already out? I just got one today w/ GTB esc from one of my local hobby shops for a killer deal
Now all I need to do is wait on the 10.5 SS
JayBee is offline
Old 03-12-2007, 05:30 PM
  #2019
HI JayBee...do you have a # for the new 13.5 SS Pro ...? and does the new motor have ribbed endbells.?Thanks
Adrian.
ernie is offline
Old 03-12-2007, 05:52 PM
  #2020
JayBee's Avatar
Adrian.
I wouldn't intentionally steer you wrong Brah...Here ya go
The # is 3413...
JayBee is offline
Old 03-12-2007, 06:02 PM
  #2021
Be Careful...I see the old motor being sold on other online hobby stores using the same part number
DOTMAN is offline
Old 03-12-2007, 06:24 PM
  #2022
JayBee's Avatar
What's also weird is that on Novaks website, it's saying that the new 10.5 SS motor with the 'blue' timing ring (that you can't tamper with, the 13.5's timing ring is 'orange' ) is available....can anyone confirm this?
JayBee is offline
Old 03-12-2007, 06:58 PM
  #2023
What's also weird is that on Novaks website, it's saying that the new 10.5 SS motor with the 'blue' timing ring (that you can't tamper with) is available....can anyone confirm this?
Thanks JayBee...it's just where ever I look I have to wait till April to buy one.
ernie is offline
Old 03-12-2007, 10:42 PM
  #2024
i need some help. i installed my GTB and 3.5R motor, did the one touch setup. the motor runs fine. sounds good and everything. the only thing is that on the Blue and Amber led's stay on permanently on the ESC. at neutral the Red LED stays on at full throttle the green comes on and at full brake the green flashes. all the while through this the blue and amber LED's stay on.
is this correct? if not what does it mean??
Old 03-13-2007, 12:50 AM
  #2025
rampal's Avatar
I think blue and amber mean that you have drag brake on, that is the standard setting on the profile 1. Thus is correct.
cheers,
rampal is offline
