New Novak Brusless System >
Old 07-14-2010, 06:53 AM
  #2686
Company Representative
Originally Posted by tr1kstanc3
Just getting back into 1/10th scale and have a GTB brushless w/Velociti 5.5 and wanted to know what's the new/fastest Novak motor I can run with this older system?
The GTBs are rated down to 3.5 turn 540 Ballistic sensored motors and 4.5 turn Ballistic 550 motors.
NovakTwo is offline
Old 07-14-2010, 07:13 AM
  #2687
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Thanks for the prompt response. I will look into it.
tr1kstanc3 is offline
Old 10-13-2010, 04:46 PM
  #2688
hacker's Avatar
Trader Rating: 141 (100%+)
do the old ss pro series motors have a temperature sensor like on the ballistics?
Useful for GM speedies with temp cut out!
hacker is offline
Old 10-14-2010, 08:40 AM
  #2689
All Novak motors since the original 4300 and 5800 versions feature a temperature sensor (blue wire). This motor temperature overload protection feature requires an esc that monitors motor temperature:
Thermal Overload Protection (Also referred to as Thermal Protection):
Thermal Overload Protection is a built-in sensor which shuts down the MOSFET(s) when its temperature exceeds a preset level. This circuitry provides protection from overloads. Dual-level protection cuts the throttle in half when the ESC temperature reaches unsafe levels. If the temperature continues to climb, it will shut down.
TeamNovak Glossary of Terms
Our Havoc 1S, 2S and 3S controllers feature this protection and are compatible only with motors featuring this temp sensor.
NovakTwo is offline
