Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 03-14-2006, 04:31 PM
  #8146
gone_wheelin's Avatar
Thats what they told me when I called to check on the availability.
gone_wheelin is offline
Old 03-14-2006, 05:21 PM
  #8147
i_got_m8_4_$85's Avatar
what do you mean by inconsistency of the gearboxes?
i_got_m8_4_$85 is offline
Old 03-14-2006, 05:25 PM
  #8148
Hi guys, I have something that I don't quite understand, it has to do with setting up the TC4 chassis. I hope I explained it right. If I'm right. they say to use a ride high gauge. By sticking it under the chassis at all four Corners and adjusting shocks. To get the same 5 mm at all 4 Corners. That part I understand. Now they say find the center of the chassis which then you would put knife edge at the back or the fund and lifted slowly to see what comes off the set up board first. And then they say to adjust with the shock that's the part I don't understand if I'm doing something wrong or going about it wrong I appreciate some help you but that's too different adjustments on the same shock. Help
rc10bob is offline
Old 03-14-2006, 06:21 PM
  #8149
Jsaves's Avatar
rc10bob
Shock question. What you want to do is find the center of the front and back of the chassis. Say you are trying to get the front shocks adjusted. So you use your center in the front and use a xacto knife to lift up that center spot. You now watch what tire lifts first.
You adjust the opposite rear shock collar down until the front tires lift at the same time.
Now do the same for the back and you are done.
What you are doing is making sure there is the same pressure on each tire at each end of the car. It will make the car more consistant which is always nice.
God Bless
Jsaves is offline
Old 03-14-2006, 06:51 PM
  #8150
jsaves ,Thanks for getting back, that part I understand. But now when I go to adjust to ride high. I've got a screw on the shocks Up or down. And then that change is the thing you just only to do. How do you adjust the ride high, and then adjust where you get the ties to come off the set a board at the same time one is throwing the other one off. That's what I think.
rc10bob is offline
Old 03-14-2006, 06:58 PM
  #8151
Jsaves's Avatar
Getting the tweak equal will effect the ride height a little.
So if the car has an equal tweak, the tires lift up at the same time, then the ride height might not be exactly the same on every corner.
Set your ride minium first then do the tweak and only go down on the shock collar so your car will still be above your ride height.
God Bless
Jsaves is offline
Old 03-14-2006, 07:03 PM
  #8152
OK.
rc10bob is offline
Old 03-14-2006, 07:25 PM
  #8153
hey everyone i was wondering if someone could give me a setup for rubber tires to start off with please.
mush104 is offline
Old 03-15-2006, 05:36 AM
  #8154
DaveW's Avatar
God Bless
To add to this, be sure your droop screws are adjusted so they do not affect your rideheight adjustments. I have seen some people have the droop screws adjusted down on the chassis so they cannot get proper rideheight. Not that you are having this problem, but it is always good to look for it when tuning your car.
DaveW is offline
Old 03-15-2006, 05:55 AM
  #8155
Are you running on carpet or ashpalt?
JK41 is offline
Old 03-15-2006, 06:47 AM
  #8156
im going to be running on carpet and it should be at like a med for traction.
mush104 is offline
Old 03-15-2006, 06:57 AM
  #8157
1.I removed the four blue chassis stiffeners, 2.From the center of the top plate remove the second screw from the front of the chassis and remove the screw closest to the rear of the chassis. 3.Then run 60wt oil in the front, 40 in the rear, blue springs up front and silver in the back. 4.If your car is traction rolling, put the medium or light sway bar on the front.
This setup was the easiest to drive
JK41 is offline
Old 03-15-2006, 07:00 AM
  #8158
thanks for the setup and help.
mush104 is offline
Old 03-15-2006, 11:05 AM
  #8159
Default Rubber on carpet setup
Mush: There are a couple of rubber on carpet setups on the Associated website: http://www.rc10.com/racerhub/setup/0...ad.htm#RC10TC4
I believe there is one for the tub chassis and the FT chassis.
Old 03-15-2006, 12:44 PM
  #8160
Trader Rating: 22 (100%+)
The inconsistancy of the gear boxes...ok easiest way to put it is that you would have to shim either the motor mount and/or the gear box in order to get everything to line up square. The gearbox's were only off by a few thousandths, which is probably way inside their tolerance. Problem is when you match it up to something else that wasn't made in house at AE you might have a few thousandths here and then a few thousandths on the BMI end and that adds up. I know that it took me a long time to get it just right but when I did, it was perfect.
Bob Barry is offline
