Team Associated TC4
#646
My LHS told me yesterday it would be 12/1 for FT parts.
#647
That isn't too bad
#648
TC4 "C" hubs ARE available had them at the LHS i work at also the "kick up " shim set that includes the little pivot balls for the hinge pins, replacements coming in day to day and i also heard about 12/1 for factory team parts
#649
Originally posted by Kyew
heh heh. it's not graphite. just weigh your TC4 and you'll know............
Xray - 46.something
Losi - 46.something
TC4 - 49.9(OUCH)
Yokomo - 49.9(without motor cam, clamp, pinion gear, battery strap)
My car didn't have a transponder either!!! What's the Slim Fast diet for the TC4? hahaha.
Dave, do you have to go through Yokomo Japan to get Associated parts in Japan? Or could you get the parts from elsewhere?
#650
-Dave
#651
DAVE.
I see from your signature that the TC4 is up top, followed by the Pro 4, the 415 and the Barracuda.
Is that your order of preference? Sounds about right to me - possible a swap between positions of Pro 4 and 415!
#652
all I have left are the shocks. Who ever is in charge of quality control should be fired! Hinge pin too long and I had to cut it shorter, silver ball stud hexes were not deep enough and I could not get the hex head into it, and no treadlock included. Frustrating to say the least and I won't have it up and going. Not much room in the cvd end and diff. Other than that the car is better than the TC3 and I did not have to sand anything. I would feel bad for any new person in the hobby putting together their first TC. I can't wait to get it to the track.
#653
Originally posted by kt racing
Apparently you don't read directions very well. You were supose to build the shocks first. And the directions tell you that the front and rear hub pins are short and long. I had no problems with the ball studs either. So I wouldn't blame the manufacturer for you not being able to follow directions.
I have been told that the stock diff. are steel, so if your running stock you could use the plastic diffs. and save a fair amount of weight right??
Alum. screws would help too...
#654
Clearly, if you build the shocks last instead of first, the car will handle horribly.
#655
Any body know where I can get a sway bar kit for tc4?
#657
sway bars arent's available yet
#658
Originally posted by wannabee
Ouch,lol
Ouch,lol
#659
you racing saturday?
#660
Originally posted by Nella-Nobrob
The stock diff is composite.....
