Team Associated TC4
#8131
Originally Posted by AM03GT
both sides? fronts are symmetrical left/right
rears are symmetrical left/right
cool i was just makin sure
#8132
Originally Posted by SUNA
How would you guys rate the FT TC4 vs. T2 or FK05 or JRXS
Need some opinions before shopping.
TC4 is a lost cause indoors. It simply does not function in the same manner as the inline belt cars. Indoors on carpet it is at a disadvantage. I hate to say so but believe the hype, get an XRay or a Corally for indoor carpet.
Outdoors on rubber and asphalt, it has a much better chance as do all the shaft cars.
#8135
I drove a BMI car not a FT car. They are similar but the BMI seems to be a lot more aggressive due to the shifted batteries, electronics...etc. My TC4 would turn on a dime...it was never an issue. I ran it mostly on carpet.
This was my starting setup:
Front
70 wt losi oil
2 piston
purple springs
inside on arm
2nd hole out on tower (laid down)
camber - 2nd hole out silver ball stud no washers
4 deg castor
5mm ride height
droop - 2mm over ride height
steering rack - silver ball studs no washers
2 shims in front of arms
no shims under blocks
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
Losi XXXS Zero deg hubs inside on hub no washers
no washers under blocks
5 mm ride height
droop - 2 mm over ride height
double pink
no sway bar (this made a huge difference)
BMI Chassis/top deck/ motor mount
Team Express C2 (19T) geared 35-104
Team Express IB3800's
Parma Alfa
Front
70 wt losi oil
2 piston
purple springs
inside on arm
4 deg castor
5mm ride height
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
5 mm ride height
double pink
Parma Alfa
#8136
Front
70 wt losi oil
2 piston
purple springs
inside on arm
4 deg castor
5mm ride height
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
5 mm ride height
double pink
Parma Alfa
Front
70 wt losi oil
2 piston
purple springs
inside on arm
4 deg castor
5mm ride height
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
5 mm ride height
double pink
Parma Alfa
#8138
Bob: So you start with running the hinge pins flat? That almost seems to simple.
#8140
Yes they did and it was dialed.
wat you mean by "was"?
#8142
think he meant the motor mount
#8144
Unfortunately they are not making the mount any more because of that vary problem.
