Team Associated TC4
#8882
Originally Posted by LaxRacer
DaveW
How many washers are you running with those losi hubs ??? and which hubs are they ?
C
C
By washers i assume you mean whats under the ballstud? With that said i run none... its a silver longneck ballstud... and i use a black shortneck inside... and make my rollcenter/washer changes there. As mentioned, they are Losi rear hubs, the 0 degree NON offset hubs.
#8883
Originally Posted by RCpurplecow
hey DaveW, where'd you get those CVD's? How much do they affect performance?
The CVD's are original TC3 goods... the composite AE parts. They are like 10$ for four of them. They are great for stock and 19T with diffs... one-ways and spools will break them easily. That set i have literally had for years... they last forever when used with the light plastic outdrives. They are mainly for stock, to remove as much weight from the driveline as possible to get a little faster throttle response... in 19T ill use them with a plastic rear diff and a lightened-steel front diff to add a bit of flywheel effect to the driveline, the steel diff adding weight on the nose for more steering on/off throttle, and makes it a bit easier to throttle drive the car. (well for me anyways)
#8884
Actually I was refering to the hinge pin or wrist pin for the hub. The ones I have are just smaller then the AE opening, so i had to put 2 washers on the pin to keep it from floating on the pin.
Hope that makes sense. If my girl didn't have my camera I would take a picture of mine.
C
C
#8885
C
C
AH! Sorry... i use no shims as seen in that pic... its a front arm on the rear of the car... the fit is just right with no shims. When i DO use a rear arm, i use two .030 shims, one on each side of the hub to place it in the center. If that isnt enough shims to keep it from moving around, then use a few smaller shims to snug it up... but not so tight that the suspension binds. Losi makes a shim kit that has shims with the same inner diameter as the AE TC4/3 outer hingepins... regular motor shims fit the inside hingepins. The arm should move up and fall freely under its own weight with no shock attached... if it does not then the shimming is too tight. There is a fine line of too tight and too loose... to remove ALL of the hub and arm slop, the suspension will not move freely... unlike all of the current cars on the market that seem to have "better" fit and finish.
#8886
I just built my TC4 and see a problem. Hope you guys can help me to slove.
My TC4 has installed the following: 27T stock motor, Futaba MC800C esc, s9550, 203HF and Orion Lipp 3200.
The problem of my TC4 is the left and right turn is not balance. First I understand all the cars have uneven left and right turn. But my case is soo extremely. When I turn right, everything is fine. Making a nice circle. But when I turn left the car makes the turn tooo fast and turn too much. It is not controlable. I have check everything like downstop, camber, linkage position, shocks and confirm they are 100 % setup correctly. Do you know what cause the problem? Do you think too much play on the front suspension caused this? Thanks!
#8887
Rear Hub Carriers: XXX-S(LOSA2226)
i was looking at the other part number i posted.. and they look offset..
so it has to be the losa2226
#8888
I've just noticed the same problems as ioxqq. Anyone know a fix? The steering lock is the same both ways so I think it might just be the weight balance throwing it off. At my track we run clockwise, so most of the turns are right handers. I just can't carry the same corner speed through there as other cars. Will have to balance the car again and see if it's better.
#8889
ralph_c: I think this is not much related to the balance. As I went tc3 for like 4 years running 3300mah battery. The TC3 is even more not balance then tc4. And my TC3 is prefectly running. So, I assume balance is not the most issue here. It must be something else mainly.
#8890
Other than that, i would check to see if you have any damaged steering parts (hubs/wheelbearings/etc), and check to see if you have the same caster blocks L/R... maybe you have a 2* on one side and a 6* on the other?
#8891
Put 20% less turn on the left than on the right on your Radio. It's a well known problem.
On the tc3 left and right C-hub were different and that why there wasn' any problem.
#8892
This would be a problem if he goes lock to lock with his steering... do you set your car up to go lock to lock? I use 100 on the DR and 55-60% of throw L/R and dont even come close to bumping the caster blocks, on either car. I wonder if the link from the servo to the steering kit is arranged properly... if it isnt, it will act like he stated also.
#8893
Yes it could be also the the link from the servo to the steering kit that isn't arranged properly. But if it's so violent i'm sure he have to much steering on left. it's due to the shaft.
Th tc3 c hub give a difference of 16 % less (estimated) on the left.
#8894
#8895
"Special" One-Way Diff beariings
Does anyone know the dimensions for the p/n 1731 bearings for the Heavy Duty One Way p/n 1729? Associated gives them as 3/8x5/16, but that can't be correct because the standard ball diff bearings are 3/8 id x 5/8 od and these bearings go in the diff housing at the same place. The standard 3/8x5/8 bearing is also too small to fit on the One-Way. I wonder if the "special" means these are metric (maybe 10x15mm?) or something like that.
Any help would be appreciated,
Thanks,
Bob J
Thanks,
Bob J
