Team Associated TC4
#9031
I run a front and rear swaybar on my Jammin. The thicker the sway bar, the less steering you will have (less weight transfer from side to side). I haven't tried to drive it without a sway bar on the front yet, but i haven't had much time to actually make it to the track and test.
#9032
ok quick question if anyone knows that would be a great help, first off i want to thank the guy who showed me the diagram of the steel outdrives. i ordered the neccassary parts to rebuild the tranny and diff, NOW my question is when its all put together how tight should i tighten the t nut and screw. is there a factory spec for this???
#9033
i'll give my personal suggestion. it's a little wasteful but it works... i have the rear end of a tub car setup just to check diffs... it works the same as using the rear transmission... just put the diff in and close the case, have wheels on the rear... grab the left wheel ( for steel diffs) with your left hand and put your left thumb on the spur gear. then use your right hand to try to turn the the right wheel... don't crank hard, just grab the wheel with your fingers and twist... if the diff is set right it should not slip... (i usually twist with two fingers to set for my preference, this part comes from experience and doing the adjustment enough times to know how you want your diff to feel) from here you can adjust for a smoother diff or a tighter diff depending on preference, the easy way to do this is to remove the right wheel and detach the upper camberlink... the rear hub will swivel out of the way for easy access to the diff screw... repeat as necessary...
#9034
3.5 Brushless in TC 4 Speed?
I am planning on putting a 3.5 Novak brushless system in my TC 4 and changing to metal outdrives. What kind of top speed will I be looking at and what other changes should I make. I will of course put the GTX ESC in as well. Any advice will be helpful.
Gofast
Gofast
#9036
Correct Gearing
What gearing would you reccomend for that setup. I have a TC4 that I can race, I was just trying to build a speed demon. I may end up taking the add-0ns off and putting them in the TC5 when it comes out. I am prety new when it comes to diffs and gearing and so forth!
Gofastrlbrown
Gofastrlbrown
#9037
have a tc 4 for sale with novak velocity 6.5 velocity brushless motor. and gtbesc...with all manuals,,,sway bars ,,ect,,,,needs radio gear ,,,great car,,,lmk,,,[email protected]
#9039
Regional Moderator
Gofastrlbrown
Gofastrlbrown
#9040
Bmi Tc4 4sale
BMI Tc4 285.00 shipping also comes with Reedy Pt "Platinum" Modified Motor.......and a 17turn motor, will throw in a used Novak Explorer ESC I don't know if it still good but will throw in anyway .Also will throw in A BODY autographed by Brian Vickers.No electronics.
#9041
Guys I'm trying to find a place, hobbyshop preferably, that has a supply of the carbon rear arms, I believe part number is AS31009.
I just installed my last spare one and would like to stock up on them while they should be still available.
Other requirement would be post internationally.
Thanks in advance
Thanks in advance
#9042
Have you tried Kellots Hobbies or Ace Hobbies (same company, one is retail and the other is distributor - for AE in Australia). They are located in Sydney and are very helpful. Ask to speak with Steve Burgess or Gary Kellot. Otherwise, I know that Trackside RC (in Brisbane) also has stock of TC4/TC3 parts. Ask to speak with Jeff Hamon.
Hope this helps.
Leonard.
Hope this helps.
Leonard.
#9045
My bad missed the location
