-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
NOZ69 03-26-2005 07:34 PM
Re: Rack Cover
Originally posted by NOZ69
I`ll give it a go, i`ve got some scrap lexan lying around
Cheers
Just made one..:D
Took all of 5 mins & looks like it will do the job nicely.
Cheers
revzalot 03-26-2005 08:11 PM
Got pix?
Aries326 03-26-2005 11:31 PM
Asiatees & GPM TC3 Parts
Originally posted by killingtime
FYI - I've had some of GPM parts overdue two months from asiatees.com. For awhile they would return my emails about why they haven't shipped, now they're starting to ignore me.
2 months? Shoot, I start going crazy after something doesn't arrive a few days after someone has promised it will arrive. I'd cancel the order and cancel it from your credit card if they've already charged you for it.
NOZ69 03-27-2005 12:54 AM
Originally posted by revzalot
Got pix?
Sorry... camera`s busted,
But there is a pic of the finished cover in the link.
Cheers
Trixter 03-27-2005 07:11 AM
Re: TC3 Maintenance
Originally posted by Aries326
As far as bearing cleaning goes, I've read that people here go as far as opening up the bearings. Is this necessary or can I just buy the "bearing blaster" and use that to clean out the bearings? Or can I just spray the cleaner directly onto the bearings without spending $9 for the bearing blaster? Thanks for the tips...
The best way to clean bearings is to take the covers off, blow them clean with motor cleaner, lightly apply bearing oil (one or two drops) and reassemble. If you want to loosen up your car, leave the cover off one side (the one that faces inside). The drawback is that you will have to clean them more often.
Aries326 03-27-2005 12:16 PM
Re: Re: TC3 Maintenance
That's a big drawback. I think I'll leave the covers on them. I'm not looking to race weekly. Thanks for the tip.
fjm9898 03-27-2005 11:41 PM
how do i make my tc3 competive on carpet?
i have a tc3 factory team and it seems like everyone has the xray and they are always beating me. i just got a bmi chasis for my tc3 but havent run it. what else can i do to help my little tc3 on carpet or should i just give up and spring for an xray
fjm9898 03-28-2005 08:37 PM
are graphite shock towers better? do they help the car at all?
ones like these - http://cgi.ebay.com/ws/eBayISAPI.dll...965551241&rd=1
Secret_weapon 03-29-2005 09:29 AM
Where can I find "HOT" option parts for my TC3
Charles Leto 03-29-2005 01:59 PM
i'm going to get a FT TC3 kit here soon and was wondering if all carbon is better than all composite i will be running on carpet more than asphalt
DOTMAN 03-29-2005 02:06 PM
www.speedtechrc.com
Aries326 03-31-2005 11:45 PM
100T Spur 64P TC3
I just bought a Factory TC3 with a 100T Spur with 64P. What size pinion should I use with it? I'll be using a P2K2 Pro Stock Motor with it.
Chin_z 04-01-2005 05:55 AM
The guys at my track run a 31T pinion and the track is a small tight carpet track has good results. I am running a 32/96 and am staying right with them. I would suggest talking to the people at your track and see what they are running or asking what there drive ratio of there TC3 and then set your car car to around the same ratio and play from there to get the most out of it.
Aries326 04-02-2005 06:22 AM
Thanks for the quick reply. I'll give that a shot.
speedracer008 04-02-2005 06:23 AM
is the carbon fiber chassis really worth getting?
