Yes, then your odds go way up on finishing a race.:D
Originally posted by JWATT Yes, then your odds go way up on finishing a race.:D |
Get a late model body, some rallye tires, and join them!!!!
Ok, I'm gonna open up the thing and clean out the diffs and the bearings. I just got a bunch of parts in from RCBOYZ.
Has anyone ever gone through the arduous task of reading all the messages in the TC3 forum and compiling a TC3 FAQ? It would be cool if we had a FAQ that addressed common questions regarding diffs, maintenance, springs, links to mods, etc... That would make it easier for noobs like me to get info and make life easier for the experts so they don't have to address the same questions over and over again. Also, can you tell just by the color of the part if it is a team factory graphite part or a regular composite? The TC3 I bought is a team touring but from all the pics I've seen of the team factory, it seems to have the same color chassis. Thanks for the help... |
Originally posted by Aries326 Has anyone ever gone through the arduous task of reading all the messages in the TC3 forum and compiling a TC3 FAQ? It would be cool if we had a FAQ that addressed common questions regarding diffs, maintenance, springs, links to mods, etc... That would make it easier for noobs like me to get info and make life easier for the experts so they don't have to address the same questions over and over again. As i`ve only just brought a TC3 too & when using "Dial-up" going through 326 + pages looking for info is NOT an option.:( Cheers |
Steering Rack Cover
G`day ppl`s,
Has anyone used this "Steering Rack Cover" [part # 3857], is it worth while getting one over doing the NTC3 mod. Cheers |
Re: Steering Rack Cover
Originally posted by NOZ69 G`day ppl`s, Has anyone used this "Steering Rack Cover" [part # 3857], is it worth while getting one over doing the NTC3 mod. Cheers Getting back to my point before, we should get together and make a FAQ that has useful links and info... |
Re: Re: Steering Rack Cover
Originally posted by Aries326 to make a cover for the steering rack out of lexan. I`ll sus out Associateds website. Thanks for the tipoff. Cheers |
Rack Cover
Took some tracking down but I found it...
Link to the D.I.Y. Rack Cover http://download.teamassociated.com/p...rack_cover.PDF I`ll give it a go, i`ve got some scrap lexan lying around Cheers |
TC3 Maintenance
Ok, the TC3 I just picked up from eBay is totally apart. The bearings and gears are soaking in WD-40. Before I put it all together again, are there any special changes I should do other than what is shown in the manual? Extra shims I should put on to improve performace or prevent gear stripping? How much diff grease should I put on? When I opened up the tranny case, it was absolutely filthy. The guy I bought it from must have put a ton of grease on the gears.
As far as bearing cleaning goes, I've read that people here go as far as opening up the bearings. Is this necessary or can I just buy the "bearing blaster" and use that to clean out the bearings? Or can I just spray the cleaner directly onto the bearings without spending $9 for the bearing blaster? Thanks for the tips... |
I race a BMI tc3 on carpet that is a very small lots of turning track. I need a nice setup the rear of my car is all over the playce.
Rite now im runing 5 droop all around 5 ride hite. 60 weight in the front 50 in the rear. Purple springs in the front and copper in the rear. and a front sway bar. I need a new setup my car is handeling very poorly anyone got some suggestions? |
I just noticed that both ends of the top half of my diff cases have holes in them right under where the middle screw for the shock tower goes into. Is this normal?
Also, if I buy a new TC3 tranny case, will this solve the binding problems I keep reading about or has the problem not been fixed by Associated yet? Will I need to buy a TC4 tranny case or one of those RDL Aluminum Tranny cases? Definitely I think there is binding. Before I took this TC3 apart, the tranny wasn't that smooth. It would maybe keep turning for 1-2 seconds. Thanks for the help... |
Originally posted by Hp1RaCeR I race a BMI tc3 on carpet that is a very small lots of turning track. I need a nice setup the rear of my car is all over the playce. Rite now im runing 5 droop all around 5 ride hite. 60 weight in the front 50 in the rear. Purple springs in the front and copper in the rear. and a front sway bar. I need a new setup my car is handeling very poorly anyone got some suggestions? |
Originally posted by RC Noob website? |
Originally posted by Aries326 GPM makes some cheap aluminum parts for the TC3. Check this link out: http://www.asiatees.com/model.php?br...odel=TC3&pid=1 |
| All times are GMT -7. It is currently 10:09 PM. |
