-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
Red Z 03-22-2005 07:11 AM
I have a problem:
On my TC3 rear diff I have a horrible sound coming from the ring and pinion gear. Sounds like really poor mesh. I tried new gears, shimming until my fingers bled, new bearings, new parts, and I'm at my wits end. It is still there! Suggestions?
JWATT 03-22-2005 07:55 AM
I assume the other diff is fine. Swap pinions, then diff assemblys, to see if you can isolate the problem.
revzalot 03-22-2005 09:51 AM
When I hit throttle from standing, the car tends to veer left. I've already checked toes and camber but it still veers left. You think it's loose diff?
Nova F1 Racer 03-22-2005 10:14 AM
Check your tweak.....
revzalot 03-22-2005 10:43 AM
How do you check tweak? I just bought a tweak board. Do you add weigth first and then adjust shocks collars? Anyone have a systematic way. This is my first ep car.
JWATT 03-22-2005 11:21 AM
First, take shock off arm and verify that the arm will drop by it's own weight. If not then you probably have a bent hinge pin. Remove springs and check "pack" on the shocks. Make sure the rebound is the same. Verify that the shocks are the same length, need only compare fronts to themselves and rears the same. Re-install shocks, set ride height. Shock collars should be at approximate same setting. Put on tweak board, car should be neutral. If not, car is tweaked. Put chassis on a flat surface (glass is best) and see if chassis is flat. Adjust shocks to get car flat. If collars are not close to same, be sure springs are same length. Be sure shocks are mounted the same when comparing side to side (for ex. outer hole on one are, and inner hole on the other, same with top mounting). Another way to check tweak is to put car on flat surface, find exact center of car, and lift car at that point. Tires should leave the surface at approximately the same time. Check droop too.
Hope this helps.
RC Noob 03-22-2005 05:54 PM
whats the cheapest place to get carbon fibre hop-ups, and some other aluminum hop-ups for my tc3?
thanks in advance:D
Nova F1 Racer 03-22-2005 07:12 PM
thanks in advance:D
ebay
RC Noob 03-22-2005 08:29 PM
BESIDES EBAY! lol i dont like bidding..lol if its cheap..there always someone using proxy
Secret_weapon 03-22-2005 10:02 PM
Anybody with a good TC3 setup for asphalt.
I run factory team, Quantom Compotition2, 12x1 Surikarn.
Any good gear ratio?:eek:
Red Z 03-23-2005 12:31 AM
I think that Calandra makes cool aluminum parts for the TC3. Different colors too if I recall...
RC Noob 03-23-2005 07:36 AM
website?
revzalot 03-23-2005 07:43 AM
You can try teamirsrc.com
Aries326 03-24-2005 01:53 PM
thanks in advance:D
GPM makes some cheap aluminum parts for the TC3. Check this link out:
http://www.asiatees.com/model.php?br...odel=TC3&pid=1
Aries326 03-24-2005 01:58 PM
Just got a TC3
I just picked up a TC3 Team Touring on eBay. I'm not sure how well this was taken care of or if the gears are as smooth as they are supposed to be. Should I take the whole thing apart, relube the diffs and clean out the bearings?
