-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
SA_Racer 03-04-2005 04:27 AM
Originally posted by RC Guru
is there like a hop up diff that comes already built or something like that?
for $50 Ill build one for you ;)
Galactik 03-05-2005 11:38 AM
New gearing suggestions?
I am new to RC, so I am still learning things. I am running my TC3 with stock gearing, 72T spur with a 25T pinion for 19T motors. I am wanting to start experimenting with new gearing to help learn more about the car.
Can anyone recommend some gearing or links to guides on gearing? Anything would be greatly appreciated.
Thanx.
DOTMAN 03-05-2005 02:27 PM
I'm not sure what 19T motor you're running, but if you're running a Reedy or C2, you're final ratio is way too high. I run my Reedy between 5.8 and 6.0. The C2 I run between 5.9 and 6.3. I should say that I do run on open tracks.
Red Z 03-07-2005 10:29 PM
What r u guys using for bearings?
tc3stocker 03-07-2005 10:30 PM
ACER Ceramics
marzin 03-08-2005 11:19 PM
Hi Guys,
Any suggestion to remedy a few stripped diff case screws (top)?
Cos if I hit something, the screws would pop/open case as a result.....
ThePrfctGetaway 03-09-2005 05:22 AM
I have some of those, but the screws don't come out, at least, last time I checked.. :lol: What happened? Tightened them too much? Mine were already stripped when I got it.. :( I wonder if putting CA Glue in it would work... it could bond to the plastic and create the threads out of glue, as a temporary fix it COULD work... don't know if it WILL..... :confused:
JWATT 03-09-2005 05:53 AM
Buy 5/40 screws. They are a little larger, and use the same 3/32" driver. You will have to drill out the top holes of the diff case so the screw will be loose in it.
Nella-Nobrob 03-09-2005 06:04 AM
Originally posted by MikeDeadly
The composite CVD's are lighter but would really only hold up if you are only running stock. The lighter material would help you get up to speed a tad bit quicker due to the less rotating mass, but again this would only be for stock. The composite cvd's would not be able to take the stress of mod racing.
--Mike:batman:
Am running composite CVD's in the rear both on my TC3 and TC4 in mod without any problem. I have not broken any so far.
Manfredo 03-09-2005 07:50 AM
How many of you guys are using the direct bolt-on parts of the TC 4 on your TC 3. I´m talking about shock towers, main shaft, and the chassis stiffeners with the upper link mounts ?
rayhuang 03-09-2005 07:59 AM
The only TC4 item on my tc3 is the rear camber link/side posts. I am running the stock rear shock tower in conjunction because the TC4 rear shock tower (graphite) deflects all over the place when you compress the suspension.
NOZ69 03-11-2005 01:43 AM
G`day ppl`s,
Looking at buying a 2nd hand TC3.... is there any particular area that i should look at closely.
marzin 03-11-2005 09:05 PM
Hi
The CA worked temporary as for now, holding the diff case nice and tight....... another issue to solve though..car is too loud! :)
Do you put any lube to your gears ?
Thanks ! :)
S.Stew 03-11-2005 09:11 PM
I run the Chassis braces and shock towers. I had the tc3 shock towers on there but then i just bought the TC4 peices for the heck of it. It works pretty good. Mainly i like it cuz it allows for a little higher roll center in the front.
RC Noob 03-12-2005 10:11 AM
hey guyz, i used to be RC GURU changed my name, well, umm i was wondering, if you guyz know where i can get aftermarket diffs (pre-built would be nice), hop-ups basically, for a cheap decent price.
