what are drift tires and where do you get them .Do you also put them on the front or just on the back? :rolleyes: :rolleyes: :rolleyes:
drift tires are a super hard compound rubber tires(HPI) or you can use the yokomo drift tires :smile:
if you want to save money just use pvs or abs piping and cut it to the liking of your width :) you put drift tires on all 4 wheel |
oh ya i dont know if your lhs has those hpi or yokomo frift tires but you can get all those (PVC,ABS,Yokomo,HPI) on ebay :smile:
Originally Posted by BatJam1
Does anyone know what i would have to do to convert my TC3 to a drift car?
Originally Posted by rpmmaxxed
can anyone suggest a good body to run at socal?
Looking at the stratus 3.0... Previously ran an S2000 for kicks, but I know it was a hinderance. Any info is appreciated. Thanks. The Mazda is the best all around body... although I ran a stratus AP last weekend which was pretty good at getting rid of the oversteer. Really can't go wrong with either one. |
hey henry hows it goin :smile:
i just wanted to see if you got my Pm i sent you with my address just tell me whats up K? |
Can some one help me when chossing a Stock motor for my TC3 - needs to be a 27t stock motor , no mod motors please . And I also need a pinion gear too . So any info to help my choice would be great . I will be running on a carpet track , that is fairly tight . oh yeah , cheaper the better .
Try either a trinity PK2 Pro, or a green Machine , or a Monster!As far as gearing we dont know what your running for a spur , what tires, what size diameter they are.Just remember to go down a tooth or 2 if you use the monster.Its more RPM based than the other 2 motors . :nod: :nod:
Well i don't know the size of the tires , they are foams , and I am using a 72T spur , i bought a 32T pinion , but I think that was a mistake .
if your using 48 pitch gears you should start with a 26 or a 25 tooth pinion,and try to measure the tires diameter i run my tire at 57mm.
Is the bolt pattern the same on the main chassis of the tc3 and the tc4? :confused:
no its not just the four bolts that hold the diff down !
hey guys umm... the manual for the tc3 on ae's website is the old tc3 without droop screws and i was wondering if someone can help me out here by telling me where i can get the recent tc3 manual :smile:
Thanks |
:weird: Batjam1 you seem to know alot about electric car .Im :confused: would you run 26mm tire on electric, :tire: I wouldn't! Does anyone know.
Thanks newera152 |
batjam1 thats foam 26mm!
| All times are GMT -7. It is currently 03:16 AM. |
