You might try www.speedtechrc.com
or more direct http://www.speedtechrc.com/store/ebp...?catmainid=164 Also where can I get info on the nitro tc3 steering mod you can do to your ele. tc3 so the steering is smoother. I checked in previous posts but their were 300+ pages so I didnt check them all. Thanks |
Originally posted by marzin Hi The CA worked temporary as for now, holding the diff case nice and tight....... another issue to solve though..car is too loud! :) Do you put any lube to your gears ? Thanks ! :) |
Is there life still in the TC3
New too the ELectric sean, I been running Nitro for the past Three years (Under the Kyosho Banner) so when a friend let me drive his Losi xxxs which I enjoyed... Hats off to all Electric Races.....
My questions have to do with the TA TC3 1) the race does not seem to turn in. I plan on testing with the Barry Baker setup form 2003 Reedy Race TC 2) since the turn in on the Losi is much shaper I was think of maybe use the xxxs' spindle&wheel carrier on the TC3 . They both look to be around the same size but the Losi's steering pivit ball seem to be shorter(meaning better steering. working like place two holes on a Nitro TC3 knuckle. 3) Has any one used or heard anything about the BlueBird servo. For $55.99 they offer 19? oz /.13 @6v Thanks...And I can't beleave i'm racing no getting into Electric..... I take back all those wise crackes... |
Does this sound right..?
G`day ppl`s,
Picked up a TC3 Team Kit today, & after going over it I sussed out the gearing. It seems a bit high & the pinion is huge. Motor : Tamiya "Sport Tuned" Black Can Spur : 65 Pinion :35 This gives a final ratio of 1.85:1 I brought it of a guy who knows what he`s doing , so i`m guessing it`s okay. Just thought i`d ask. The track i`ll be racing on is a tight technical , shortish straights , & low to medium traction..& concrete netball court surface. Also any recomendations for a Spur/Pinion combo for a 540 motor on the same track. Cheers |
hey what size tires are you guys starting with for foam on carpet, and asphalt, I mean what are you truing them dowm to?
On Carpet- i just run the std 26mm by fast tyre, 40 front, 35 rear and just adjust the pinion as it wears down. Ive never skimmed them down so i dnt know it it makes any improvement :confused:
"Truing" tires keeps them from being oddly shaped. Lots of guys at my local track do that. All you have to do is keep track of the rollout and adjust the gearing accordingly.
what aftermarket parts/factory parts from the tc4 can fit the tc3??
Originally posted by RC Noob what aftermarket parts/factory parts from the tc4 can fit the tc3?? As i had a bit a "sh!t" jam my steering on the weekend, I`ve only had my TC3 for a few days, so i don`t know how often this happens. Cheers PS , If not could someone please post a link on how to modify the steering to NTC3`s / TC4`s. Thanks again |
Re: Does this sound right..?
Originally posted by NOZ69 G`day ppl`s, Picked up a TC3 Team Kit today, & after going over it I sussed out the gearing. It seems a bit high & the pinion is huge. Motor : Tamiya "Sport Tuned" Black Can Spur : 65 Pinion :35 This gives a final ratio of 1.85:1 I brought it of a guy who knows what he`s doing , so i`m guessing it`s okay. Just thought i`d ask. The track i`ll be racing on is a tight technical , shortish straights , & low to medium traction..& concrete netball court surface. Also any recomendations for a Spur/Pinion combo for a 540 motor on the same track. Cheers Raced on Sunday & took out all 3 heats & the A main..:D :D So the gear ratio`s were spot on for this track. Cheers |
Originally posted by NOZ69 Could you use the TC4`s chassis so you could get the "Bell Crank" steering rather than modify the TC3`s..? PS , If not could someone please post a link on how to modify the steering to NTC3`s / TC4`s. Thanks again http://ca.geocities.com/[email protected]/index.htm Hope that it works for you. I tried it on mine and didn't really like it, it felt like I did not have as much steering. |
thanks in advance :D |
front and rear shock towers
main drive shaft (with outdrive cups) spur gear adapter chassis stiffening braces (necessary if you want to use the shock towers) CVD´s i think that´s about it... |
Originally posted by Chin_z Here is the link. http://ca.geocities.com/[email protected]/index.htm Hope that it works for you. I tried it on mine and didn't really like it, it felt like I did not have as much steering. I got a spare chassis with mine so i might give it a go on that. So you didn`t like it... Mmmm Anyone else had any bad reports on this mod. Cheers |
TRF Shocks
wassup yall? just installed the TRF dampers on my TC3. And yes they were expensive! Anyone else try them out? What you think?
| All times are GMT -7. It is currently 08:59 PM. |
