Originally posted by RandyB are the new input gear and diff gears a running change in the new kits and how can you tell if you are buying a new kit? |
yeah I was curous about the material the gears were made of I know of the other running changes
thanks |
Originally posted by RandyB Did associated ever come out with a different input gear. like a white-ish colored one?? |
Originally posted by RandyB yeah I was curous about the material the gears were made of I know of the other running changes thanks Ray |
Originally posted by rayhuang RandyB-I too wish I knew what that material is-but to be honest-it doesnt seem to make any noticeable difference. So much so that I have about 5 diffs built at any one time (IRS, stock ones) and some have Grey gears and some have the White gears. I put them in and take them out between white and grey crown gears. Makes no difference on track at all. Ray (Yes, I get very excited after my fourth cup of coffee) |
I guess it looks trick though!
I think they are a bit stronger...main improvement.
is it very difficult to make the battery tray larger, so the batteries are closer to the cars centerline? Ive seen the website how-to's but they use drill presses and other such tools, and was wondering if anyone has done it here, and if they thought it was hard. (man that was a run-on sentence...lol)
I did mine by hand with a dremel tool, i didnt think it was too tricky at all, just take your time and mark out how much your cutting off first :)
Originally posted by Java1970 ... but the stuff IS a differend color, only difference in the gear. |
Originally posted by runnin rc10 is it very difficult to make the battery tray larger, so the batteries are closer to the cars centerline? Ive seen the website how-to's but they use drill presses and other such tools, and was wondering if anyone has done it here, and if they thought it was hard. (man that was a run-on sentence...lol) You might want to work with a big fan next to you, blowing the carbon fibers AWAY from you. That way, you will not be breathing in all the little carbon particals in the air :D |
Originally posted by Bubblestc3 You might want to work with a big fan next to you, blowing the carbon fibers AWAY from you. That way, you will not be breathing in all the little carbon particals in the air :D |
On my third or fourth chassis, it dawned on me that breathing in that stuff was not good. I was coughing that stuff out :lol: !!
I have heard that you could "wet sand" the chassis(although with a Dremel, which is electric might not be a good thing) to eliminate most of the fibers. George told me this right after preping my EVOIII chassis... DOHH! |
1 Attachment(s)
Originally posted by Bubblestc3 On my third or fourth chassis, it dawned on me that breathing in that stuff was not good. I was coughing that stuff out :lol: !! I have heard that you could "wet sand" the chassis(although with a Dremel, which is electric might not be a good thing) to eliminate most of the fibers. George told me this right after preping my EVOIII chassis... DOHH! Here is a picture of the side of my chassis. Like I said, I used 200 grit to round off the edges, and 1000 grit for the wet sanding. |
1 Attachment(s)
Close up.
After wet sanding the chassis is incredibly smooth to the touch. |
| All times are GMT -7. It is currently 02:17 AM. |
