-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
anthony390 11-12-2005 08:36 PM
does any one know if i have 30-40 mph tc3 on a bumby road like a street,... would the composite CVDs snap on the part that is the universal?
oh ya i have steel outdrives and a bit tighted
THANKS
Trixter 11-13-2005 08:55 AM
2 Attachment(s)
I've been using the composit CVD's and the plastic diff halves ever since I built my car, I've run a 9 turn motor and not had any wear at at all, however I also use the Schumacher 'blades' on the end of the CVD. See photos
anthony390 11-13-2005 10:51 AM
thanks but what i was wondering is the part on the CVD that is connected to the axle (axle that hold hex hub and wheel)
what i am wondering is if it would crack or snap there
Thanks :smile:
anthony390 11-13-2005 10:52 AM
oh ya where did you get and what are the Schumacher ''blades'' :confused:
thanks :smile:
anthony390 11-13-2005 11:01 AM
never mind i found out what and where i can find them :smile:
BIG DADDY8 11-13-2005 12:01 PM
Originally Posted by RED-LINE M03
I am thinking of buying this car what would be a good price?
TC3 BMI 2mm & 3mm chassis
Thanks,
E
Does the BMI chassis make that much difference on the handling????
anthony390 11-13-2005 12:07 PM
im not that sure if it makes a difference that you can notice that easily but it does
i do know that it makes it quite STIFFER and so ya
hope it helps you :smile:
newera152 11-13-2005 12:28 PM
I was thinking about getting one for my TC3 and was talking to the guy at the track friday nite, they say every body they know the used it has a big change in handling. :nod: also whats the biggest spur gear that will fit on the TC3, I have 100 and upthey just look to big to fit.
newera152
RED-LINE M03 11-14-2005 04:06 AM
BMI TC3
2 Attachment(s)
4-SALE BMI TC3 ( BMI, IRS, NIFTECH, ACER, RPM )
http://www.rctech.net/forum/showthread.php?t=90486
PaZ 11-15-2005 07:38 AM
anthony390- soz mate my comp caught a worm lol all i did was remove the bearings from the diff gear thing and tightened it right up, its taken everything drift on road racing and some carpet racing. But i wouldnt do it with plastic ones they may melt lol like mine did when it got loose.
Nice BMI mate, i had the blue warpspeed demon it didn't make a massive improvement in handling but looks nice. Iv'e now gone back to the FT graphite chassis and found it just as good.
anthony390 11-15-2005 03:46 PM
thanks PaZ for the info but you said bearings
i have a goldish colored bushings in my plastic and steel diffs
a bit :confused:
sorry
PaZ 11-15-2005 04:04 PM
I ment the bearings in the actual gear, when u take the diff appart the gear in the middle comes off and its got lots of little ball bearings in it :blush: take em out lube up tighten up fully away u go :)
Aries326 11-15-2005 04:15 PM
Awesome! Those make total sense - evenly distribute all that power instead of concentrating it on the pins. Will those also fit the steel or aluminum diff halves?
anthony390 11-15-2005 04:23 PM
oh i c i tought the gold bushing that goes on the diff outdrive but ok :sweat:
i out2 try it
PaZ 11-16-2005 11:56 AM
hope it works out ok
