Re: bearings
Originally posted by tom235 when you spray out your bearings do you spray out the ones on the wheels or do you just leave them alone |
thanks
do you think it makes that much of a diff. with the 8 bearings not cleaned out? |
i know for a fact that it does, but it matters how bad they are. i know a guy that cleaned his well in the middle of a race day and accually consistantly ran 0.2-0.3 seconds quicker
the wheel bearings get dirty faster so it is much more important to keep those clean!
thanks guys i will have to try that.
does anyone have some more speed tips?:D i have all ready done the diff bearings and the housings and move the bat. to the center. |
what kit is it. is it a factory team? because if so there is not much you can do. unless you are running on carpet. then if you want to spend the money i would look into getting an IRS carbon chasis or a BMI to look into stiffining the car up. but if your not a team car then getting the graphite converson kit would be a great start. I am selling an IRS TC3 take a look >>>> http://www.rctech.net/forum/showthre...threadid=67863
Carbon Fiber Shock Towers for Elec TC3
Ok... so I searched the archives & the only carbon fiber shock towers that I can find are made by Square R/C and those only seem to be available at Speedtech R/C . Does anyone know of any other brands or places to pick these up? I'd appreciate any leads. Thanks in advance for you help.
Adam |
Penguin R/C makes them as well. You can also get those through speedtechrc
I am new to touring car racing and I have a TC3. When setting the front droop do you set it to the flat part of the arm or the dimple in the middle near the outer edge?
Thanks |
Go to AE's site, and look at the manual, it will show you how to do it. You can also print it if you want.
Originally posted by fjm9898 what kit is it. is it a factory team? because if so there is not much you can do. unless you are running on carpet. then if you want to spend the money i would look into getting an IRS carbon chasis or a BMI to look into stiffining the car up. but if your not a team car then getting the graphite converson kit would be a great start. I am selling an IRS TC3 take a look >>>> http://www.rctech.net/forum/showthre...threadid=67863 |
then the Ft is great for out doors. really the only major things left to get speed are high voltage batteries, tuned motor, driving skills, and having the right set up for the track. those will make the most difference but there are still other little things such as ceramic bearings but only hard core racers use them because they dont do much, they are very expensive, and they break easily. the moral is driving skill and set up cuz they dont cost much (if anything) and they make the most difference
Originally posted by DOTMAN Penguin R/C makes them as well. You can also get those through speedtechrc |
thanks fjm9898 for all your help :D
Diff Thrust Bolt Question
Hi People,
I'm building up a diff using the IRS lightweight alloy outdrives. It calls for a combination of AE parts from the lightweight kit ("D" rings) and the heavy duty kit ("T" Washer) and I have a question about tightening the thrust bolt. Per the manual, you tighten until the spring is totally compressed then back off a half turn. However this is for the lightweight diff with the "captured" thrust retaining bolt. When using the "T" bolt, this seems to me to give a pretty loose diff, and I'm wondering if this is correct? I know with the off road diffs, they use the same "T" bolt, and they call for the bolt to be nipped up and then backed off 1/8th of a turn. Can anyone give me any ideas about an initial setting for my setup, using the "T" bolt? Thanks MIKE |
| All times are GMT -7. It is currently 11:16 AM. |
