Tamiya F104 Pro!
#3781
yes i did have to grind it down, very easy. Im going to run the splitter and put the helmet, i just didn't have the time to finish and i wanted to post pictures and thanks for the compliment
#3783
PS-0549 F103シャーシ用レーシングスリックタイヤ (R3-S)リア ソフト
2本入り インナースポンジ付属 定価1050円(税込み価格、本体1000円)
http://www.pit-shimizu.com/
#3784
I'm in the process of painting my F60 body... I'm going to run the dorsal fin and one of my T-cams... it's going to look hot!..(I hope... lol) http://www.shapeways.com/model/15686...ml?gid=sg49707
#3785
& Had TRG F103 Tire
Front had 3 type , Rear had 2 type !
http://rcmarket.com.hk/index.php?man...2aqlkrarik0107
#3786
Tamiya F104 Black Special released !
#3787
What servo is prefered in this class. Obviously it will only take a standard sized, and likely doesn't need 120+oz touring servo, but does anyone find the need for something other than a 'standard' servo
#3788
Check out this article on Dave Jun's build for the F-104
http://www.tamiyausa.com/articles/fe...article-id=442
#3789
Chasing some advise....
Is there any performance/grip difference between the Mclaren, Ferrari, or other bodies of the same model kits?
What is the best Tamiya rear & front rubber tires to get?
Which kit out of the F104's generates the best grip?
Appreciate your help... thanks...
#3790
#3791
#3792
I havent tested the Mclaren body, but comparing the generic F-104 body to the Ferrari F60 body showed the ff: (it was confirmed by Danny Hua, the TCS F-1 champ)
Ferrari F60 has more rear downforce hence slight understeer
F-104 body has more front downforce hence slight oversteer
mixing wings and body combinations is not allowed in Tamiya-sanctioned races but may be allowed in others.
im also considering testing non-tamiya F-104-compatible bodies and compare them as well... results soon
the option Hard front/ Soft rear of tamiya for the F-104 seems to work well. just sauce it up a bit with traction compound (if allowed in your races) and if you have tire warmers handy, use 'em.
and as far as F-104 kits having best grip? i'd say its the Pro kits (standard ver. or black ver.) since it has hopups which make the car good to drive. as opposed to the stock kits...
hope this helps
#3793
I plan on getting one of these early next year and am doing some prepping now. Any place to get decals the right size based on real F1 cars? Im not really a ferrari guy, but bmw/redbull would look great.
#3795
