Tamiya F104 Pro!
#3751
Thats how I got mine to free up.
#3752
I'm nearly finished building my f104 and just when I went to test fit my IP 3800 lipo that fits everything. It doesn't fit
lucky I have some old stick packs. Are there any corally plug packs that fit? If not do I just have to get some stick pack lipos?
Also I may have asked this somewhere but what is a good 64 pitch pinion/spur combo for silver can?
#3753
#3754
yes you might need rounded lipos, dont think the square sided ones fit / plug
#3755
#3758
Use a spare arm and a spare ball to test with, sand down the ball in small increments until you find the right size (sorry I don't remember what the measurement was, sold my car) and then replicate on the rest of the pivot balls.
#3760
What equipment do you use to true your Tamiya tires down?
Are you trueing your tires after each race, or is there a need for new ones?
#3761
I put those inner pivot balls in a dremel and slowly sanded them with 1200 grit. Butter! However, be careful because you can easily sand off too much material.
I tried the pop the arm on and off many times and it still has not loosened up...plus I'd have to do that every time I change the arm which I'd rather not do.
The low friction ones might be a solution but unless they have a threaded stud on them I'd need to lock tight in a long set screw. On my F1-09 I used a threaded stand off to make it easier to open the top deck.
