Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 11-03-2010, 02:39 AM
  #3631
Trader Rating: 51 (100%+)
Originally Posted by rc_square24
Do you guys tweak this car? If so how is it done to get both tires lift off the same time? (as there is no side spring tweak screws)
On my last race day, by the third heat my car was oversteering/spinning out of corners on left turns while steering right it's pretty planted even on throttle.
I then noticed at the end of the day my front left tire is about 2mm smaller in diameter compared to the right (55/57). It was my first time racing it so i'll keep an eye on the diameters next time in between runs.
I suspect that would be why it was inconsistent in left/right turns?
Anyways I'd still like to know how to un-tweak the chassis.
Make sure to rotate tires (left and right) every now and then to get even tire wear.
Apex is offline
Old 11-03-2010, 01:04 PM
  #3632
Can someone tell me whats a good alternative to the Futaba S9650 servo? I am kinda looking for KO propo but not sure where to find the references
416XBEN is offline
Old 11-03-2010, 01:52 PM
  #3633
gashuffer's Avatar
Trader Rating: 48 (100%+)
1/12 scale servo? Maybe the JR. The Ko one is over 100 dollars. Way over priced. I use a Futaba 51 low profile. Works like a champ.
gashuffer is offline
Old 11-03-2010, 01:56 PM
  #3634
Do you mean the BLS-651 Brushless ones??
416XBEN is offline
Old 11-03-2010, 07:29 PM
  #3635
dzstr's Avatar
Trader Rating: 20 (100%+)
I ran mini lipo's in my F104 tonight. We run 21.5 with no boost speed controls. Rubber tires on an indoor ozite carpet track.
Before the first qualifier I added 1oz of weight to the rear of the car. Better than no weight but still fought the car for the entire 6 minutes. Rear end was very loose.
2nd qualifer I kept it as is and the car was terrible as the traction came up. Others were traction rolling. I thought I was driving on ice.
Added 1oz more in the rear before the mains. That made a huge difference. I could actually pull the trigger
dzstr is offline
Old 11-03-2010, 08:07 PM
  #3636
rc_square24's Avatar
I have an Airtronics 94819 on my 12th and I really like it, just ordered another one to replace the Futaba I have on the f104. Plus it's only 40 bucks amain
rc_square24 is offline
Old 11-04-2010, 01:24 AM
  #3637
TOM NAVY's Avatar
Default f109 shell
Does the f109 shell fit in the f104 pro can i trim it to the lines or does it requier extra trimming.
TOM NAVY is offline
Old 11-04-2010, 01:29 AM
  #3638
gashuffer's Avatar
9551
I am selling one if you need it. PM me if your interested. I'll give you good price on it.
Old 11-04-2010, 01:49 AM
  #3639
How is the clamp type left hub compared to the spacer + hub form the kit?
Old 11-04-2010, 02:12 AM
  #3640
TOM NAVY's Avatar
Default SHELL
Just want to know guys my cars getting here tomorrow seconhand i want to start painting my shell or should i wait and fit it to the car first thanks
TOM NAVY is offline
Old 11-04-2010, 02:29 AM
  #3641
Foxxrocket's Avatar
If it's a 104 or F60 body from tamiya, there's no need. Third-party type bodies will need to be fitted before painting.
Foxxrocket is offline
Old 11-04-2010, 03:43 AM
  #3642
TOM NAVY's Avatar
Default .
Its third party thanks
TOM NAVY is offline
Old 11-04-2010, 11:36 AM
  #3643
TOM NAVY's Avatar
Default JORDAN
what shell and wings are best to make a jordan using the stickers from d drive sport um what shell do the stickers fit best on i sore a post with one in the fourm
TOM NAVY is offline
Old 11-04-2010, 12:53 PM
  #3644
Foxxrocket's Avatar
The only companies I know of that make bodies for the 104 are Chevron and ZEN racing. But they're the more modern body types 08' and 09'. I just used the 104 body, as it is closer to the jordan style.
Old 11-04-2010, 02:49 PM
  #3645
TOM NAVY's Avatar
ANY other tips nice job if that yours in the fourm.
TOM NAVY is offline
