Tamiya F104 Pro!
#9436
On my F104 cars with the movable electronic mounting points, I am using a Protek 5000mah "stick pack" lipo. Because the pack is rouned, the battery clears the lock nut on the bottom right side of the chassis. There is a picture of my car earlier in this thread. Here is a link...
1/10 R/C F1's...Pics, Discussions, Whatever...
#9438
You can replace the center dampening disc on the Tamiya F104 kits with the F104X1 upper deck kit. It includes a side damper in the kit which is Tamiya #54331 (https://www.tamiyausa.com/shop/optio...ll-damper-set/). You can find this kit cheaper online such as Amazon..
This kit comes with a separated/shorter upper deck, which would make removing shorty lipo packs easier. In the picture of my car a few posts above, I am using the longer version of the X1 upper deck Tamiya #54333
#9439
I am about to try that, hoping it will stop it from 3 wheeling in tight corners..
