Tamiya F104 Pro!
#3032
Does the TS020 Toyota GT1 body fit the F104?
#3033
Probably not...it was made for the F103 which is shorter than a F104.
#3034
Will side-by-side nimh packs (6 cells joined by battery bars) fit in the holder with either deans T plug or banana tubes? I also have round stick shaped lipos and wonder if they will fit?
#3036
then click "F1 something " top (?) in the menu on left hand side
that takes you to a page of large icons by manufacturer
click TRG and search those pages - thinks its on Page 1 from memory
Its a bit hard to find - but promise you its there.
Cheers
#3038
I have one on my 103.
It's not bad.
A little heavy but it's right where you would want weight.
It's not bad.
#3043
B compound foams, 57mm rollout, hard (black) springs up front, new soft t-bar with relief cut, soft spring (I prefer the short ones) and 45wt. oil in the shock and 60-80,000 diff fluid on the friction plate. Won't win you a TCS race but will get you in the ballpark @ Strictly See you Sunday ...:tire :
#3045
What is the Tamiya part no. For the soft short spring? Thks
