Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 03-03-2010, 01:04 PM
  #2281
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by akura2
Looks cool
and not to sound like a noobie (I've been in RC for more than 30 years)
what exactly does this do?
It's a lever system, when the pod moves side to side, the lever extends one of the damper tubes while simultaneously compressing the other. It probably doesn't compress either damper tube when the pod moves purely forward or backward, which is an improvement over the standard damper disk setup (b'c it decouples that mode of the suspension between the shock absorber and the dampening disk). Hope that helps.
Greg Sharpe is offline
Old 03-03-2010, 02:14 PM
  #2282
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Sharpe, I bet that system works.
104 is looking better and better.
j.d.roost is offline
Old 03-03-2010, 02:22 PM
  #2283
J-VET's Avatar
Who sells TRG? I couldn't find them anywhere.
J-VET is offline
Old 03-03-2010, 04:54 PM
  #2284
hotdognobun's Avatar
rcmart.com
hotdognobun is offline
Old 03-03-2010, 06:10 PM
  #2285
aussierevo's Avatar
Trader Rating: 14 (100%+)
it will be interesting to see the feedback if anyone invest's in them.
to settle a thought is the Renault R25 and R26 arguably the world's most attractive F1 car ever.
or is it just me.
aussierevo is offline
Old 03-03-2010, 07:33 PM
  #2286
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Eric P has run them @ wcrc, but I don't think he cared for the TRG tires, could be that he did not have the optimum compound for that surface ?
Also that was with the F109 chassis.
RedBullFiXX is offline
Old 03-03-2010, 07:37 PM
  #2287
or is it just me.
The R30 doesn't look too bad either
Old 03-03-2010, 08:09 PM
  #2288
finished it last week
Jeff Cuffs is offline
Old 03-03-2010, 08:21 PM
  #2289
aussierevo's Avatar
jeff....nice work...looks great.
I have looked at the R30 2010 Renault, and it does grow on you. I note the car tested over the weekend in Barcelona had red on the wings.
For those looking for F60 Barcode stickers, these may be of interest.
http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWNX:IT
Old 03-03-2010, 08:50 PM
  #2290
Nice, another F-104 to hit the track
Have fun !
Old 03-03-2010, 10:43 PM
  #2291
hi everyone, do anyone here know that if TEU-101BK will work with formula tuned motor? Thanks
hansenhon is offline
Old 03-04-2010, 04:16 AM
  #2292
Default who has these in stock?
im after some jaco pinks 2142 for the rear of my f104, but nobody has them in stock, any ideas?
zharn is offline
Old 03-04-2010, 04:17 AM
  #2293
Barry White's Avatar
Who makes or can make a brake light switch. I don't want a permanent light nor a flashing light becouse the permanent isn't used and a flashing one is only used in the rain.
Barry White is offline
Old 03-04-2010, 06:11 AM
  #2294
cheROK1212's Avatar
This years best looking car followed closely by the Mercedes the Lotus (check that, the Lotus is second. Absolute classic)
cheROK1212 is offline
Old 03-04-2010, 08:29 AM
  #2295
f1larry's Avatar
Trader Rating: 22 (100%+)
If you get the Tamiya TLU - 01 light unit you can use the 3 racing led light bulbs. They sell them in flashing or not flashing with out using another control. the unit has an on off switch. I am not sure how well it will fit in the f1 car though. You might even be able to use the 3 racing bulbs without the unit, not sure though.
f1larry is offline
