Like Tree3Likes
Tamiya TRF415
Old 04-14-2006 | 10:19 AM
  #13771
Originally Posted by hierog
andbody have a .pdf file of the MSX manual?
thanks
vic
Here you go!
http://tamiya.com/japan/rc/rcmanual/trf415msx.pdf
trf_racer is offline
Old 04-14-2006 | 09:42 PM
  #13772
Anyone try out the money motor in their 415? I just got a checkpoint 19t and not sure what to gear it, new to tamiya. Someone please give me a starting point. Will be on large size outdoor asphalt track with a 102 spur. Thanks!
Kingsbury is offline
Old 04-14-2006 | 10:37 PM
  #13773
maxepower's Avatar
Checkpoint motor!
I would start at 6.3 and go from there. My motor temp is around 140 F. So, this isn't hard on the motor. You can gear it more but I tend to be a little conservative, at least until I know what the motor really needs for my race track. I believe that is a 35 pinion with a 102 spur!
maxepower is offline
Old 04-15-2006 | 05:49 AM
  #13774
t4m1y4niac's Avatar
Originally Posted by Martin Crisp
That sucks...
If you use the 2 degree c hubs this will give you more initial turn in but less mid corner steering. You could add some spaces under the front hinge pin block at the front of the car to effectively add more caster back into the car to get back some mid corner steering. Start with a 0.7mm spacer then 1mm then 1.5mm and see what works.
M
thank you so much Martin...i'll try it..
t4m1y4niac is offline
Old 04-15-2006 | 03:57 PM
  #13775
xtrememadness's Avatar
i want to try mark reinards rubber tire setup on tamiyas website. can someone tell me what they mean by rebound stroke? is that the same as droop? thanx.
xtrememadness is offline
Old 04-15-2006 | 04:32 PM
  #13776
Tsquare's Avatar
Xtrem, it is the same as droop. Instead of a droop gauge, they will measure the height of the axle from the ground using a calipeir (i.e. 25mm). If you go to Tamiya USA website David Jun has an article on how to set droop using this method.
Tsquare is offline
Old 04-15-2006 | 06:27 PM
  #13777
thanx tsquare. i will check. appreciate the info.
Old 04-15-2006 | 09:52 PM
  #13778
Slotmachine's Avatar
I`m looking for part# 50994
Slotmachine is offline
Old 04-16-2006 | 10:09 AM
  #13779
maxepower's Avatar
Talking 415 MSX/Checkpoint
Did some testing with the Checkpoint motor and was up to 7.3 FDR, probably could have gone one more tooth but ran out of time. It pulling pretty good out of the corners. I'll do more testing next weekend!
Old 04-16-2006 | 11:06 AM
  #13780
Default PLease help
Hi all been on the Tamiya USA website I cannot find this article perhaps I am blind, anyone have a direct link or can explain in detail
Mark
mark34 is offline
Old 04-16-2006 | 12:29 PM
  #13781
TryHard's Avatar
try this...
http://www.thard.co.uk/tips/DavidJundroopmethod.doc
HiH
Ed
TryHard is offline
Old 04-16-2006 | 12:43 PM
  #13782
Smile
That was quick
Thanks Tryhard
Mark
mark34 is offline
Old 04-17-2006 | 07:07 AM
  #13783
John Tag's Avatar
anybody got a link to a GOOD bearing kit for the 415...
John Tag is offline
Old 04-17-2006 | 07:16 AM
  #13784
Go Here John
Old 04-17-2006 | 07:23 AM
  #13785
Turbonium's Avatar
or try here...
www.avidrc.com
they dont have sets that i see, but the individuals are reasonably priced!
Turbonium is offline
