Old 08-25-2006, 01:39 AM   #15271
TryHard's Avatar
Originally Posted by Boultspeed
It was in the sand pit end of DV, and yes they aren't new tyres .I'll try some new ones next time.
Ed set up is as kit but with DJ rear end on 20 oil and fluro red spring and 45 front oil, do you think 60 oil would be better ?
Paul.
If I remember right, I ran 50 alround at DV, so your probably not far off.
Best bet, try 60f and 30r (with the DJ).
Cause the track is smooth, you don't need the dampers to help out with bump adsoption, just control of pitch and roll, and as such can be setup stiffer.
If it was a t the sand pit end though, more than likely not gonna help regardless... how does the car feel on the rest of the track, is it just that corner/section you struggle in?
| THard.co.uk | Xray | MuchMore |
Old 08-25-2006, 03:16 AM   #15272
Boultspeed's Avatar
car feels pretty good all round , but the back end snaps out on corner entry but only on the fast corners, on the slow corners its nailed.
I was using yellow front springs and fluro red rear , do you think it would be better on blue front and fluro yellow rear with 60 oil front and 30 oil rear ?
Which toe blocks would you use ?
___________________
www.boultspeed.com
MB models (leeds)
Titanium Racing
Boultspeed is offline   Reply With Quote
Old 08-25-2006, 03:47 AM   #15273
TryHard's Avatar
Try blue on the front to start, with 50 or 60wt oil. If the car then starts to understeer on power, go to the fluro yellow on the rear, with 25 or 30wt. If it still snaps, try laying the rear shocks in one hole (I think I used hole 3 with the DJ on the rear tower).
Toe blocks... I think I ran A/XB or the front, with XC/B on the rear, so quite narrow.
HiH
Ed
Old 08-25-2006, 05:56 AM   #15274
HarshGuy's Avatar
FYI ...if you have a drill press and a round dremel grinding wheel, it's a walk in the park to get a 415 oneway to work with the MSE pulley's doesn't need a lot of material ground off at all, I set the depth on the drill press so that it took a tad off, ground one side, flipped the pulley and did the other side and viola oneway with the 36 tooth (well technically 18 if you count the teeth) pulley.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-25-2006, 07:19 AM   #15275
Boultspeed's Avatar
Thanks Ed , I'll give it a try
Paul.
___________________
www.boultspeed.com
MB models (leeds)
Titanium Racing
Old 08-25-2006, 10:34 AM   #15276
m8commando's Avatar
Does anybody have any suggestions on lipo's in the 415msx......
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 08-25-2006, 10:44 AM   #15277
TRF415boy's Avatar
Originally Posted by TryHard
Personally, I would change the rear camber link positions.... use 2 on the bulkhead, and B on the hub...
(I do remember the reason why you had it like that Fab, not ment as a dig)
Deffiently agree on the new tyre thing, thats the first thing to try.
HiH
Ed
Yeah i skipped that part when i searched for a suitable setup, lol. Well it did work well like that aswell anyway...
TRF415boy is offline   Reply With Quote
Old 08-25-2006, 11:08 AM   #15278
Tsquare's Avatar
Tamiya makes a stick pack conversion kit for the 415 MSX, that works quite well with the Orion Lipo pack. If your interested I have a NIB kit I can sell. I'm in San Diego, can get it to you quick if needed. PM me of you are interested.
Tsquare is offline   Reply With Quote
Old 08-25-2006, 11:22 AM   #15279
stuey's Avatar
it sounds like its too soft on the rear may be you should go up an oil rate and spring rate all round also lengthen your wheel base that should make the car better on the faster corners
stuey is offline   Reply With Quote
Old 08-25-2006, 11:40 AM   #15280
Hebiki's Avatar
Trader Rating: 26 (100%+)
i think m8commando's bigger concern is the 4800 orion lipo pack not being able to fit in the MSX bulkheads without having to dremel off the battery shape/curve off the rear bulkhead.
you can still use the orion lipo with the original chassis. the rear bulkhead just has to be dremeled. this problem was solved with the newly shaped packaging of the 3200mah orion lipo. there are photos in the 3200mah lipo thread.
http://www.rctech.net/forum/attachme...hmentid=160759
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-25-2006, 01:50 PM   #15281
Tsquare's Avatar
The 415MSX Stick Pack Conversion kit comes with a new right rear bulkhead and top plate that allows the 4800 Orion Pack to fit. Tamiya Part # 49385
Old 08-25-2006, 11:49 PM   #15282
Tek Nickal's Avatar
Does a 64p 120t spur gear fit the car? Also where can I get a front ball diff?
Tek Nickal is offline   Reply With Quote
Old 08-26-2006, 05:23 AM   #15283
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to HotrodHopkins
spur should fit, and you can either make your own ball diff, or get the new one from tamiya.
and my question is where can i get replacement outdrives for a shooters spool for the standard 415?
SHAUN HOPKINS a.k.a NoRod Hopkins
-1990 Chevrolet K1500 Silverado TBI350 "Heavy Half". 1971 Chevrolet Nova
-My lug nuts require more Torque than your Honda makes.
HotrodHopkins is offline   Reply With Quote
Old 08-26-2006, 06:18 AM   #15284
TryHard's Avatar
a 120 won't fit. The largest you can get in is about 108.
Ball diff... you might as well get the new tamiya alloy one.
HotRodHopkins;
You can get replacement outdrives for a shotoers spool I think, not sure where from though...
HiH
Ed
Old 08-26-2006, 07:12 AM   #15285
edracer1's Avatar
I just ordered the front diff assy from TamiyaUSA direct,
http://www.tamiyausa.com/product/ite...oduct-id=53921
edracer1 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
