Old 01-16-2006, 10:25 AM   #12271
Charles Godwin's Avatar
You need
Tamiya: 51055, 53379(or any other 3mm diff balls), 53030
Yokomo: ZS-501, ZS-506, ZS-507, ZS-508
If you don't have the LW suspension you need tamiyas 46mm driveshafts-51092(steel) or 53724 (alum)
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 01-16-2006, 10:26 AM   #12272
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by natskiboy
how do I go about getting a front diff for a 415.
Nevermind...already posted.
Steve Sohl
sohlman is offline   Reply With Quote
Old 01-16-2006, 11:10 AM   #12273
hierog's Avatar
RC Alum Diff Joint Set - TRF415
Item #53889 (COMING SOON)
High precision aluminum parts allow diff adjustment without removing joint from chassis, and are easy to perform maintenance on.
*Compatible chassis: TRF415, TRF415MS, Chassis with Item 49378 TRF415MS Up-Grade Parts Set, TRF415MSX
can somebody explain just what they are talking about? how would i adjust the diff without taking the dogbones out of the drives? what am i missing here?
hierog is offline   Reply With Quote
Old 01-16-2006, 11:52 AM   #12274
Probably a bit like the Xray. Instead of having a screw head (hex) there is just a hole in the outdrive and a holes which goes throught the screw head. Line these up then turn one way or turn the other to make the adjustment. of course you'll need to hold the opposite wheel.
Charles
Old 01-16-2006, 11:52 AM   #12275
V12
V12's Avatar
Originally Posted by sohlman
I bought a spare car that had this aluminum front diff in it. I was told someone in Germany was selling them.?.?.? I put it in my MSX...fits fine, but you must use the 42mm shafts.
Yes thatīs true. Someone here makes aluminium diff halves for a front diff. I have to say I also bought the diff halves but never tried as I like the oneway very much. Also we donīt run foams so you donīt need a frontdiff really.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 01-16-2006, 01:33 PM   #12276
TryHard's Avatar
Charles
Problem is, to get that to work on the 415 diff, the thrust race would have to be on the other side, as at the moment the head of the bolt is right in the place where the bearing goes...
I was discussing this with TRF415boy at the weekend. And the conclusion was that without a redesign of the internals, it would be darn hard to do that on the car as it is.
Ed
| THard.co.uk | Xray | MuchMore |
Old 01-16-2006, 02:02 PM   #12277
can anyone post every item needed to make the new externally adjustable diff.
thanx
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 01-16-2006, 02:34 PM   #12278
m8commando's Avatar
Originally Posted by JoeGlover
Just some fyi to the guys running the msx on carpet. I had this top deck made up and it drastically improved the the chassis flex without modifying your old mid decks. Zero tweak issue and the car was definetly more stable. Since this was a Ms conversion it has the 2.5mm chassis. I love this car!
Joe is there anyway I can get one of those upper decks, I like it.
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 01-16-2006, 07:51 PM   #12279
Burlap's Avatar
Send a message via MSN to Burlap
Sounds like another thing I have to buy. Damn you Tamiya and your tempting hopups
Burlap is offline   Reply With Quote
Old 01-16-2006, 08:09 PM   #12280
Recently I was looking at the setup sheet and can anyone explain to me what "rebound stroke" is.
Is it similar to droop?
trf_racer is offline   Reply With Quote
Old 01-16-2006, 08:22 PM   #12281
maxepower's Avatar
Exclamation symantics!!
I believe it's one in the same! Just another name for the same thing!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 01-16-2006, 11:18 PM   #12282
JimmyMac's Avatar
Rebound stroke is the same as droop. But it could be measured differently on different setup sheets/drivers. Some measure it with wheels off the car sitting flat on a setup board. They measure the top of the axle. Alot of Tamiya drivers use this method. Measurements will be like 24.5mm or 25mm. Another way is measuring droop under the arm or hub using a droop gauge. Another is with car sitting on setup board with tires on. Then measuring ride height. Then raising chassis up until the arms bottom out on the droop screws or til tires lift off the board and measure the chassis height and subtract the ride height from that to get rebound stroke. And I'm sure there are tons of other ways too...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 01-16-2006, 11:31 PM   #12283
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by V12
From what I have heard the HPI Pro4 springs are the same as Alex Racing springs.
Alex Springs are shorter than Pro4's. Alex are more like Yokomo springs.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-16-2006, 11:34 PM   #12284
MikeR's Avatar
Originally Posted by racenut
maybe you guys could help me, since you are a tamiya fanatic. I have a TAO4 pro that i hop-up with evrything i possibly could. I love the car even thouhg its quite old. could you give me some pointers on setting up my kit??? i run stock touring in asphat not so high speed tracks here in the philippines. tnx
is there a forum about TAO4?
Yes, there's an old TA04 thread here on rc tech somewhere. Advanced search should bring it back.
Old 01-17-2006, 02:15 AM   #12285
V12
V12's Avatar
Iīm talking about the black HPI springs with just the small colour code point on top of the springs. These look the same as Alex springs and a HPI guy confirmed this.
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
