Old 04-17-2006, 07:55 PM   #13801
RC TRF415 Fnt Alum Motor Mount
Item #53921 (COMING SOON)
Any idea what Fnt means?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-17-2006, 09:37 PM   #13802
Burlap's Avatar
Send a message via MSN to Burlap
Originally Posted by KilRuf
I run the MSX R2 and I have yet to rebuild my diff. This car has been through come carpet races, Snowbirds, TCS race, and now some asphalt races. So it's been through alot. Of course I also have Xenon diff balls in there with Xray diff lube and Altas diff stickers/covers. So this of course helps alot. I do readjust it from time to time. But I know I can still go through more races with it. This is in Stock and 19t. I'm thinking of rebuilding it just out of habit....
I'm running a similar setup in the diff as yours, but with Acer diff balls, but with the Yokomo plates and diff covers. I race outdoors and the diff has not given me any hassles at all.
Burlap is offline   Reply With Quote
Old 04-17-2006, 09:53 PM   #13803
Trader Rating: 27 (100%+)
Maybe "Fnt" meant "front". Maybe they call the left side motor mount front? Is there a picture of it somewhere?
JoeyE is offline   Reply With Quote
Old 04-18-2006, 01:34 AM   #13804
alan1467's Avatar
Default Short arms!!!!
Also some short arms for the LW suspension and note the Evo5 quote????
RC Short Reversible Sus Arm
Item #53928 (COMING SOON)
*Compatible chassis: TB Evo.5 TB Evo.4, TB Evo.4MS, TRF415MSX, TRF415MS and other chassis capable of using Reversible Suspension Arm. (Depending on type of suspension block, swing shaft may have to be changed from 46mm to 42mm length.
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 04-18-2006, 07:20 AM   #13805
Mason's Avatar
Originally Posted by asw7576
Are those bearings sealed or open ?
( I read Acer bearings advertisement in RC extreme magazine. They are ceramic but open design ... no seal to enhance more spin )
they are metal shielded. generally you do not want this in the wheel but my experience has proven that near indestructiveness of the 415 (and cost control whether it was planned or not. easier and cheaper to replace a steering arm than $10 bearings.) when i hit something the steering arm holds its form and just sheers off the kingpin or strips out the bottom screw lol.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-18-2006, 07:33 AM   #13806
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Do you think the TB Evo. 5 could be a typo and they meant the TA05, I don't see a new shaft drive car on the horizon with all the hype and success of the Belt drive cars everyone is usinng now
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 04-18-2006, 07:57 AM   #13807
veecee's Avatar
Trader Rating: 34 (100%+)
Judging from this, I don't think it's a typo: http://www.tamiyausa.com/product/ite...oduct-id=58371
veecee is offline   Reply With Quote
Old 04-18-2006, 08:47 AM   #13808
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Arrow RE: TB EVO V
I did notice that on the "coming soon" section on the Tamiya USA website. After reading the description of the kit, it looks like they are incorporating some features from the 415MSX design (bulkheads, steering assembly & alum diffs) wherein the new steering design could be based from the prototype that the TRF drivers were using @ the TITC races months ago or it could be the actual steering design that comes standard w/ the 415MSX kit. The only new thing I see is the short span rev arms.
Also coming soon as well are the hex slotted ball connectors 5x5mm & 5x8mm similar to the Sqaure one's (STM-11AX). The difference is that the Tamiya ball connectors don't need a nut driver wherein the one by Square you can use hex or nut driver. I believe the one's by Tamiya were the ball connectors the TRF drivers used on their MSX kits steering assembly & upper links to the bulkheads at the TITC races. (see attached picks)
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 04-18-2006, 09:45 AM   #13809
Default Atlas
I use acer ceramic diff balls, and have atlas diff covers to prevent dirt from getting in. I also use ae stealth grease in my diff. I only have rebuilt my diff once since I got my MSX, that's since january. I usually race at least once a week, and have been racing indors and outdoors.
I'm curious about Atlas diff covers. I've looked around and can't find other references to them. Can someone explain how they work and where I can buy them.
Thanks!
bobthim is offline   Reply With Quote
Old 04-18-2006, 10:01 AM   #13810
JRRobiso's Avatar
Arrow
Thanks!
Integy has them.
TRF415 Diff Covers (04)
Old 04-18-2006, 10:48 AM   #13811
HTML Code:
Integy has them.
Thank you.
Old 04-18-2006, 01:25 PM   #13812
Front Aluminum Diff Joint:
http://www.tamiyausa.com/product/ite...oduct-id=53921
trf_racer is offline   Reply With Quote
Old 04-18-2006, 01:44 PM   #13813
Turbonium's Avatar
Send a message via Yahoo to Turbonium
well, thats good that they finally are building those! i figured it was only a matter of time.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-18-2006, 02:15 PM   #13814
Here is my betting the Evo V will have the following new parts:
Pro 4/Cyclone length arms but reversable (marc was seen running a 415 with these arms)
New steering setup ala latest team driver 415 update.
The other part RC TRF415 Fnt Alum Motor Mount Item #53921 i think will be the finned layshaft cover like david was seen running at the last indoor meeting.
Rick Draper is offline   Reply With Quote
Old 04-18-2006, 02:48 PM   #13815
JRRobiso's Avatar
I thought that part #53921 was for the 415 front alum diff joints on the Tamiya USA website?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
