Old 04-27-2006, 10:56 AM   #13921
stuey's Avatar
Originally Posted by F. Alonso
Guys, I have a setup question for you guys. How would I be able to get more high speed steering without making the car steer too much in slower speeds?? I have got my car going basically how I would like it in some of the slower stuff at this particular track in question, but there is quite a bit of initial understeer (causing me to use the brakes a lot to begin rotating the car properly) as well as high speed understeer. A trait of the track is that it appears to have quite low forward traction, so when putting on the power, the rear end tends to wander and step out. To counter that I have got the car to be pretty good in the tight stuff, but not so great on the initial turn in particularly.
Has anyone got any particular suggestions that I could try? I still have to write my setup down, but basically I have:
F R
Oil: 40/40
Piston: 3/3
Springs: Yellow/Yellow
Sway Bars: None
Camber: 1/1
Caster: 4deg
Front Drive: Oneway
Center Drive: Oneway
1mm Antisquat
2deg rear toe
0deg front toe
Shock Angle: medium angle on front/fairly upright on the rear
Motor: DC Motorsports Modified
Droop: 5mm front/2mm rear
Tyres: CS27
Body: Mazda 6
having a look at this setup what lower arm mounts are you using how many washers have you got under the inner top link and what wheel spacers. also i see you have got the same shock oil piston and spring front and rear in my experiance this tends to make the car little unstable espically off power and mid corner the car tends to hook mid corner what you could try i use when running mod is.
FRONT
oil AE 40wt
17.5LB spring
3 hole piston
3rd hole shock tower (from outside)
middle hole lower arm
4deg caster
2deg camber
2.5mm spacer under top link inner. med length
1A front and rear of lower arm
3mm spacer behind lower arm wheelbase
front role bar yellow
REAR
oil AE 35wt
15lb springs
3 hole piston
2nd hole shock tower (from outside)
3deg toe in
2deg camber
0.5mm spacer under top link. long length
1xb front of arm
1c rear of arm
1deg outbourd toe in
3mm spacer in front of lower arms wheelbase
mazda 6 or rayspeed accord
centre one way + front one way
cs 22/rp24 pre glu
droop i use is set by how much spring movement between coller and retainer on the front just touching both coller and retainer (no tension tho) rear droop measred 1mm from coller to spring.
used on high grip bumpy uk circuit pretty much the same on smooth circuit apart from pistons to 2 holes front and back also fixed spool and centre pully if grip is low.
give it a go
stuey is offline   Reply With Quote
Old 04-27-2006, 11:26 AM   #13922
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default car
F R
Oil: 40/40
Piston: 3/3
Sway Bars: None
Camber: 1/1
Caster: 4deg
Front Drive: Oneway
1mm Antisquat
2deg rear toe
0deg front toe
Tyres: CS27
Body: Mazda 6
try the same droop ft and rear or 3mm ft 4mm rear I know it sounds like it will not work but try it and tell what u think
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 04-27-2006, 11:41 AM   #13923
kewdawg's Avatar
Guys, I was hoping someone here could give me the part num. of the rear universal axle for original 415? Sorry, if, the question has been asked a million times, I'm not able to skim thru the pages, right now.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-27-2006, 11:44 AM   #13924
stuey's Avatar
FRONT
oil AE 40wt
17.5LB spring
3 hole piston
4deg caster
2deg camber
REAR
oil AE 35wt
15lb springs
3 hole piston
3deg toe in
2deg camber
1xa front of arm
1c rear of arm
cs 22/rp24 pre glu
give it a go
1xa not 1xb for rear inbord sorry
Old 04-27-2006, 01:47 PM   #13925
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by bender
Lost are we Peter?
hmm.......... still waiting...
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-27-2006, 05:12 PM   #13926
will the new evo 5 lw arms make the msx work better on carpet?
Compared to using the ta04/414/415 arms.
Smoking motor.. is offline   Reply With Quote
Old 04-27-2006, 06:08 PM   #13927
JimmyMac's Avatar
How about a rear sway bar for more high speed steering?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-28-2006, 12:05 AM   #13928
Old 04-28-2006, 02:55 AM   #13929
We will see this weekend what works best @ LRP Masters in germany. You can try it already with HPI arms...
Mr_Orange is offline   Reply With Quote
Old 04-28-2006, 08:36 AM   #13930
Thanks i wonder what bit we'll have to use to replace the arms...
Old 04-28-2006, 09:59 AM   #13931
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Hey Guys,
Thanks for your thoughts on what my problems may be. I made a few errors (droop mainly) when I wrote up that rough guide of my setup and now I will post what I exactly have at the moment, but hearing the thoughts on antisquat from Eirik, it makes a lot of sense.
Anyway, this is my setup as per Ed Clark's slightly Modified Setup Sheet:
Front:
Upper Arm Position: 2
Upper Arm Spacer: 2mm
Upper Damper Position: 3
Lower Damper Position: 3
Susp Mount Spacer: Front-0, Rear-3 (block flipped so equates to 0)
Caster Block: 4deg
Camber Angle: 1.5deg
Ride Height: 6.5 (Track has some big bumps in it)
Droop: 2mm (measured on Tamiya droop guage with shocks/bars all disconnected with suspension free)
Front Drive: Oneway
Roll Bar: None
Wheel Hex: 5mm
Rear:
Upper Arm Spacer: 1mm
Upper Damper Position: 4
Rear Upright Position: C
Rear Upright Upper Spacer: 1mm
Rear Hub: LW 0deg
Susp Mount Spacer: Front-1, Rear-0
Droop: 4mm (measured on Tamiya droop guage with shocks/bars all disconnected with suspension free)
Centre Drive: Oneway
Roll Bar: None
Wheel Hex: 5mm
Shocks: In this case, same for Front and Rear
Foam Bushing: None
Piston: 3 Hole
Shock Oil: Schumacher 40wt
Spring: Tamiya Yellow
Front Toe: 0mm
Front Suspension Mounts: Front-A, Rear-XC
Rear Suspension Mounts: Front-XB, Rear-B
Bumper: Square Narrow Bumper (ala Rheinard, Maezumi, etc)
Lower Deck: 2.5mm
Front Susp Arm Spacer: Front-1.5mm, Rear-3mm
Rear Susp Arm Spacer: Front-1.5mm, Rear-3mm
Motor: DC Motorsports 9x1 Modified
Spur: 102 Pinion: 26
Battery: Harris R/C or DC Motorsports IB3800
Body: PF Mazda 6 with Std Wing
Tire: CS27W (Control Tyre with TO Medium Insert)
Okay, I think that just about covers it. Sorry it takes up such a huge part of the page, but I think that most of us benefit from learning about setup change with a setup to tackle. I like the ideas that some have come up with, but with every detail covered now, I hope that it can help even more to sort out the cars problem of mainly lack of front grip, particularly at high speed and corner entry. On power, the car turns very well.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 04-28-2006, 01:55 PM   #13932
asw7576's Avatar
I would test these :
Front:
Caster Block: 2 deg ( more vertical ).
Ride Height: 6.0
And tighten little bit ( 1 or 2 hour ) rear ball diff.
Pro Dive ( front susp. hinge pin tilted downward ) if anything fails.
Old 04-28-2006, 05:31 PM   #13933
swimbikerun's Avatar
Trader Rating: 100 (100%+)
I'm looking for a breakdown on the differences between the different suspension mounts (i.e. A, B, C, D, XA, XB, XC, XD). I know the X series are narrower but that's about it. I found a post here that there was a instruction sheet in the worlds kit that included this but that doesn't really help me. Any help would be appreciated.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 04-28-2006, 05:37 PM   #13934
Default Set up station with weight capability
Hi guys i am trying to find a setup station that also has individual weight sensors for all 4 corners of the car.any ideas.
Robitronic Avid / Avid V2
Tekin RS pro / Viper 10.5/MMP/6900
AE B44- MMP/Hacker 10.5/6900 Castle
IP 5000/50 SMC 5200/40/50
Casino Kid is offline   Reply With Quote
Old 04-28-2006, 05:45 PM   #13935
Hebiki's Avatar
Trader Rating: 26 (100%+)
search button works wonders. here you go:
http://www.rctech.net/forum/showthread.php?t=111722
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
