Old 04-12-2006, 05:59 AM   #13741
t4m1y4niac's Avatar
Originally Posted by Martin Crisp
If using the standard spacer on the rear upright provides too much overstear and the 2.5 makes the car push too much, then try splitting the difference with say 1.5mm. Perhaps that with the yellow rear swaybar will help.
hai martin, i've already try to reduce the rear toe from 3' to 2.5' and it can reduce my understeer problem but not completely gone, thanks a lot , and before i try another tips from u, my car get coallision very2 hard and broke my 4' C hub & knuckle into pieces .and the bad thing is my LHS doesn't have any spare of 4' C hub...my question is : if i'm using 2' C hub, do i have to change another set up or just plug and paly. thanks Martin.
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 04-12-2006, 06:18 AM   #13742
Barry_Hughes's Avatar
Originally Posted by TRF415boy
Are you sure it's steering you have, not lack of rear end grip ? As you have written, you have 0.5 of toe out on the rear...
Oops wrong way
Front 1XB Rear1A giving me 2.5' rear toe in.
Plenty rear grip, plenty front as well
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 04-12-2006, 10:16 AM   #13743
asw7576's Avatar
Originally Posted by TFR
I wonder where I can get that tricked set up board?
At Louis Vuitton ??
Old 04-12-2006, 10:22 AM   #13744
Martin Crisp's Avatar
That sucks...
If you use the 2 degree c hubs this will give you more initial turn in but less mid corner steering. You could add some spaces under the front hinge pin block at the front of the car to effectively add more caster back into the car to get back some mid corner steering. Start with a 0.7mm spacer then 1mm then 1.5mm and see what works.
M
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 04-12-2006, 04:10 PM   #13745
JayL's Avatar
on the new MSX the bearings have a gold side and a silver side. Which side goes out?
JayL is offline   Reply With Quote
Old 04-12-2006, 06:46 PM   #13746
What is the difference between the 1B and the B suspension blocks?
thanks
pimpjuice_101 is offline   Reply With Quote
Old 04-12-2006, 09:12 PM   #13747
JimmyMac's Avatar
(1B) block sits 1mm lower than (B) block.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-12-2006, 09:40 PM   #13748
drew85's Avatar
Anyone know what the finial drive would be using all TA05 pullys?
drew85 is offline   Reply With Quote
Old 04-12-2006, 10:12 PM   #13749
JimmyMac's Avatar
Which pulleys? Diff pulleys? If so.. 2.25 internal ratio.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-12-2006, 11:45 PM   #13750
Stein Tumert's Avatar
It has been answered a few times now in this thread...
Both the MSX and the TA05 center pully has the same no of teeth (16).
The difference is the front and rear pullys, 35 vs 36 teeth
Gives 2.25 instead of the original 2.187
Stein Tumert is offline   Reply With Quote
Old 04-13-2006, 02:13 AM   #13751
kentech's Avatar
Arrow Spool Carpet Rubber Tyre Setup
Carpet season is basically over but if anyone's looking for some last thing to try you could try my MSX spool carpet setup. Works really well, easy to drive and stable as a spool car but really good steering. That's just my opinion though, would be interesting to hear another opinion of it. Setup is for rubber tyres.
Check out my blog for the setup. I'll try to be a more active posting stuff there that I find out from now on...
http://kentech.blogs.se
Direct link to setup is:
http://www.netikka.net/kentech/415ms...er06_spool.PDF
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 04-13-2006, 07:37 AM   #13752
ICEMAN's Avatar
Just wanted to let everyone know that the TCS race in MEMPHIS, TN is coming up in two weeks, APRIL 30, Sat. we have a Club race any car brand can run and Sun. is the TCS race, we have 48 entries so far, i you can check out more at www.tamiyausa.com or our club site at www.msra-racing.com , CYA
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 04-13-2006, 08:56 AM   #13753
Anyone know what type of belts are on every picture that show TA05 pulleys upgrade ? Are 415 standard belts ? Thank you in advance.
Mafodda is offline   Reply With Quote
Old 04-13-2006, 09:04 AM   #13754
Trader Rating: 37 (100%+)
Originally Posted by Eirik
Hello Anthony,
Well not much is happening here at the moment actually! Indoor season is over and we still have to wait for the snow to melt before we can run outdoors....
Glad the setup worked good for you!!
Noticed you where selling allot of your Tamiya stuff.... whats the reason for that??
Catch you later
Too many things going on right now for me to run EP TC this summer. So I am selling it all and will get another TC come fall.
If anyone is interested I'm selling my 415 and MSX as one package.
http://rctech.net/forum/showthread.php?t=109828
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 04-13-2006, 10:01 AM   #13755
Charles Godwin's Avatar
I know that reducing the wheelbase from the rear wishbones gives you more quicker steering but is this the same if reduce the wheelbase from the front, also i will be giving the rollbars ago, what are the noticeable differences in driving a car with rollbars when you haven't used them before?
Cheers, Charles.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
