Old 10-03-2004, 01:36 PM   #4096
had my first go with the 415 in deep rain today. Gotta say it was fun.
Throughout all my qualifying and first final i didnt alter much but was all round unhappy with the car. It worked AWESOME in the luke warm dry though. ill post my setup later.
I was using the spool and just had a mega case of chatter, causing it all to bind up. and when i reduced the lock, mega understeer....
In my last final though i smacked in my 1way the rain was Very Bad. The car was wayy better. Had great turn in , stability but just lacked from some understeer out of corners.
I think the Fixed diff just understeered alot more then the 1way which i didnt like.
I think im going to try the inboard toe out on the front. Any pointers how to go about:
using inboard.
More turn in, less bind.
Im running 19t and the new suspension.
thanks
eVo
Evo_Uk is offline   Reply With Quote
Old 10-03-2004, 01:42 PM   #4097
Default TRF 415 M
Hi all,
When will the TFR 415 M be available?
It looks killer.
Thomas
840918001 is offline   Reply With Quote
Old 10-03-2004, 02:12 PM   #4098
TryHard's Avatar
Originally posted by kansasracer
Can someone explain to me the concept behind tamiya's suspension blocks. Looking at the manual...I am not clear, like what block + what block get what?
So If I want 1.5 toe in in back....is it the d block inside and the a block in the back?
Sorry, first Tamiya car and don't get it...
Thanks...
try this, hope it helps.
http://www.thard.co.uk/rc/TRF415/Toe%20blocks.jpg
Look at the middle chart for the standard suspension (ie with 2 deg hubs) and the lower one for LWT (or 1 deg hubs).
The top chart gives the inboard toe, without taking into account the hubs additional toe.
regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-03-2004, 02:25 PM   #4099
rtypec's Avatar
Originally posted by g4t2
Has anyone actually realised that MS stands for Maezumi Satochi? It is a 415maezumi edition, not medal special.
The Medel Special Edition is somewhat of an inside joke. Yeah, we know the MS stands for Rubino Edition
rtypec is offline   Reply With Quote
Old 10-03-2004, 02:47 PM   #4100
Default Foam Tire Racing
Here is some pictures I taken on the mod in the rear of using a Front Swaybar in the back. On the Rear Arms you will notice a small molding release point. That I reference and drilled the hole and tapped with a 3mm screw for the ball stud. Use the front sway bars kit, so you'll probably want to order a spare sway bar set. This allows 28mm and 30mm tires on the rear no problem.
I think the sway bars will work pretty close to the same as the original location. May be a slight difference.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 10-03-2004, 02:52 PM   #4101
Default Foam Tires Racing Part 2
Here is the pictures from the back on the Foams installed. You'll notice my shock is on the inside hole on the arm but with the first pic, it can be put back on the outside hole no problem with the 28mm Speedmind foams as first shown. I also filed the upright's top portion for the camber link to clear these 28mm and 30mm tires. I believe the aluminum uprights would not be a problem at all with the pictures of its design that I seen.
Now with the 30mm Ellegi Rear Tire installed. No rubbing anywhere. You unfortunately lose the shock outside hole adjustment on the arm.
Old 10-03-2004, 03:00 PM   #4102
Default Foam Tires Racing Part 3
Now for the Front Tires trying to run 28mm on the front. Tamiya did not think to well for the use of foams. I think the Kingpin Ball stud on top does not go down far enough. I see almost a 1mm gap as it seats on the steering knuckle before the C Hub. Don't keep on tightening or you will strip out the threads in the plastic. To eliminate the ball cups from rubbing, just chop their heads off a little. See below:
With the 28mm Speedmind Foam installed, it's close but not rubbing! The wheels spin freely. This should be the case with most 28mm foam tires unless they change the wheel diameter on you to be a bit smaller.
Hope these pics help. Any suggestions or concerns guys?
Old 10-03-2004, 04:35 PM   #4103
Ballsie's Avatar
I use the 6mm hubs on the front to save the wheels rubbing.
Ballsie is offline   Reply With Quote
Old 10-04-2004, 02:29 AM   #4104
BKK
Went racing this past weekend at FRC with the LW suspension. I noticed that my wheels where rubbing on the front suspension. I placed the wheel spacers on there and it was still rubbing. Any sugestions? I have my travel set at 70%. I'll figure it out.
I also bouhgt the aluminum rear hubs for the LS suspension. Try that out at the next race. It came in 1.5 degrees.
BKK is offline   Reply With Quote
Old 10-04-2004, 03:58 AM   #4105
mashimaro's Avatar
so what does MS in 415MS really standard for?
mashimaro is offline   Reply With Quote
Old 10-04-2004, 04:01 AM   #4106
Holmenkollen's Avatar
@V12
Do you know wich car Reinhard and Fischer used at the CS-race this weekend?
Outdoors they seem to prefer the 415.
Holmenkollen is offline   Reply With Quote
Old 10-04-2004, 04:42 AM   #4107
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Default Re: TRF415MS
Originally posted by kentech
source: http://www.teamjoybox.com
looks like a full option 415 only things that i dont see are aluminum rear hubs, aluminum servo/ transponder mount and the belt guide
buboy28 is offline   Reply With Quote
Old 10-04-2004, 04:47 AM   #4108
slowhand's Avatar
Send a message via ICQ to slowhand
MS is the initial for Maezumi Satoshi
I found this at www.tq-racing.com .
slowhand is offline   Reply With Quote
Old 10-04-2004, 07:10 AM   #4109
mashimaro's Avatar
so is there an actual list of different parts on it?
Old 10-04-2004, 09:38 AM   #4110
V12
V12's Avatar
Originally posted by Holmenkollen
@V12
They both used the 415 with the old suspension.
Guess what...? Overall place 1 + 2.
Both prefer the 415 over the EVO IV and will be running the 415 at the worlds. Just spoke with them yesterday.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
