Old 10-12-2004, 10:22 AM   #4246
Balugz's Avatar
Trader Rating: 16 (100%+)
Default Re: Rear belt question?
Originally posted by badboy
Can I use the 415 rear belt on the 414m2?
Yes u can.
Balugz is offline   Reply With Quote
Old 10-12-2004, 11:40 AM   #4247
53804 TRF415 REINFORCED DIFF JOINT 2000YEN 28TH
51190 TRF415MS FRONT DAMPER STAY 900YEN 26TH
51191 TRF415MS REAR DAMPER STAY 1100YEN 26TH
here are the pt. numbers for the new parts, anyone know anything about the diff joints?
g4t2 is offline   Reply With Quote
Old 10-12-2004, 11:46 AM   #4248
Ballsie's Avatar
Did you get those part numbers from rainbow ten?
Are the dates October or November?
Ballsie is offline   Reply With Quote
Old 10-12-2004, 11:47 AM   #4249
Yes they are from r10, they are November.
Old 10-12-2004, 01:03 PM   #4250
Arun's Avatar
these are just the white delrin rear diff joints, same as what appeared on the original prototype.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 10-12-2004, 02:18 PM   #4251
tony q's Avatar
Originally posted by Proficar403
Here is the 415 front diff I made using EVO3 parts:
what parts of the evo did you use to build the diff for the 415?
tony q is offline   Reply With Quote
Old 10-12-2004, 02:45 PM   #4252
Leini's Avatar
this setup is for medium traction asphalt tracks.hugo wanted this one. we had to use cs-27 rubber tyres. the car is narrow, yes. you can put 1,5mm washers in the front to get a wider front. the rear is much wider with the alloy hubs as the front is.
ah iforgot, rideheight 5mm front and rear....
Leini is offline   Reply With Quote
Old 10-12-2004, 02:59 PM   #4253
Thanks Leine,
I'll try it this weekend.
See you
Hugo is offline   Reply With Quote
Old 10-12-2004, 04:42 PM   #4254
Leini's Avatar
ok, tell me about your test then....
Old 10-12-2004, 07:18 PM   #4255
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Ok... When does the new TRF415 Kit come out? I heard they were going to upgrade some stuff on the car, arms, shock towers.. Anybody know when its coming out and how much? Thanks..
vi3tishduy is offline   Reply With Quote
Old 10-12-2004, 08:46 PM   #4256
FW-05RR's Avatar
late November followed shortly by another new TC from Tamiya
FW-05RR is offline   Reply With Quote
Old 10-13-2004, 05:06 AM   #4257
Leini's Avatar
this is NOT a new tc from tamiya. only an updated version....
Old 10-13-2004, 05:28 AM   #4258
you could always upgrade the current 415 & save your hard earned dollars, i've partly upgraded my TRF 415 suspension kit etc. the end result is? the same, but you also have the advantage of switching to the original TRF 415 setup, wich some drivers still prefer
flysti is offline   Reply With Quote
Old 10-13-2004, 05:31 AM   #4259
Ballsie's Avatar
flysti - that's what I'm gonna be doing come late november. I wonder when the other new components (i.e. 2.5mm chassis plate) will be release?
Old 10-13-2004, 05:33 AM   #4260
should be available in november
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
