Old 12-01-2005, 03:23 PM   #11596
Originally Posted by HELLOkitty
thanks for the pix
Dont worry more better ones will be put up tomorrow. Its got the square front knuckles on it as well.
Rick Draper is offline   Reply With Quote
Old 12-01-2005, 03:36 PM   #11597
rcchuckyb's Avatar
Send a message via AIM to rcchuckyb
Rick: With those square front knuckles, can you fit 28mm foams without mod. I saw a picture some time ago on this thread with foams and knuckles that looked like that but forgot to ask then.
rcchuckyb is offline   Reply With Quote
Old 12-01-2005, 03:42 PM   #11598
TRF415boy's Avatar
I can answer that, i got them too. No you can't they're the same as the LW suspension and just have another hole for the steering turnbuckle. With the 5mm hexes 24mm rims comes very close to the knuckle, i'm using a 0.5mm spacer in there to prevent rubbing.
TRF415boy is offline   Reply With Quote
Old 12-01-2005, 04:45 PM   #11599
Buyer Beware
sounds good to me...thanks ...kitty
HELLOkitty is offline   Reply With Quote
Old 12-01-2005, 07:36 PM   #11600
EDWARD2003's Avatar
Default Setup suggestions please!
Hey guys i have a standard 415. This i the problem with my car. When i exit a corner and put the throttle down the car is really loose. Its almost like its on ice. But when i enter a corner the car hugs a nice tight line, it doesnt get loise. What should i do.
This is my setup so far
F/R Shock Oil) 40 wt
F/R Springs) Blue/Yellow
F/R Shock Tower Mount Holes) Outter Most Hole/ In one hole
F/R Sway Bars) Yellow/Yellow
F/R Roll Center) 2 mm / 2 mm
F/R Camber) -1.5 deg
F/R Toe In) 0/2.5 deg
Front Caster 4 deg
F/R Droop) 3.1mm/3.8mm
Ride Height 5.5 mm
Thanks for you help.
Edward Pickering.
EDWARD2003 is offline   Reply With Quote
Old 12-01-2005, 08:32 PM   #11601
dodo's Avatar
Send a message via Yahoo to dodo
Front Caster 4 deg
Ride Height 5.5 mm
Edward Pickering.
loose as in sliding around or?
dodo is offline   Reply With Quote
Old 12-01-2005, 10:29 PM   #11602
Dongskie's Avatar
Trader Rating: 44 (100%+)
Default My 415
Here's a pic of my 415... very stock but whata performer...
Bajer 1/5th
Dongskie is offline   Reply With Quote
Old 12-02-2005, 12:28 AM   #11603
Eirik's Avatar
Front Caster 4 deg
Ride Height 5.5 mm
Edward Pickering.
Hello,
Reduce front droop to 5.0mm, lower the front reide height to 4.5mm, move your front shocks inn one hole on the tower and put a red rear swaybar on/run without any swaybar at all.
This will help allot with your problem and make the car more balanced!!
Eirik is offline   Reply With Quote
Old 12-02-2005, 03:47 AM   #11604
Burlap's Avatar
Send a message via MSN to Burlap
Nice looking car. What bearings are there in it, don't look like Tamiya ones in there.
Burlap is offline   Reply With Quote
Old 12-02-2005, 06:21 AM   #11605
TryHard's Avatar
Look like ACER ceramics. I have them on my car atm, very free
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-02-2005, 06:36 AM   #11606
Dongskie's Avatar
Thumbs up
Oh I'm susrprised you noticed that... yes they are Ceramic bearings..
Bajer 1/5th
Old 12-02-2005, 09:16 AM   #11607
Customworksking's Avatar
Trader Rating: 73 (100%+)
Arrow car
Front Caster 4 deg
Ride Height 5.5 mm
Edward Pickering.
1st go to TRYHARD's web site and print youe self a few setup sheets........ok what tyers r u running and how old if there wore out u need new ones ...say if the car turns in fine but on exit it gets real frontend happy /loose its the tyers if there new then its the setup try 5mm ride H in ft 5.5mm in the rear no sway bars 5mmdroop FT 4mmdroop rear zero rollcenter D/D ft blocks everything else is ok
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-02-2005, 10:16 AM   #11608
EDWARD2003's Avatar
Default 415 Setup
Hey guys the tires i am using are CS-22's which are less then a week old.
So you want me to incrase the Droop to 5.0 mm in the front and have the rear at 4.5 mm? Why such a huge amount of droop? Usually i run 1.5 in the front and 2.0 mm in the rear.
BTW i have been racing for 7 years now so i know my setup game with tweaking the car and balance so that isnt the problem.
Edward
Old 12-02-2005, 10:52 AM   #11609
Charles Godwin's Avatar
Hi guys, i've finally got round to ordering a Tamiya MSX for Xmas . I was wondering what is the biggest (or something near the biggest) 48dp spur gear that can fit and what make of spurs fit (i can get RW and Kimborough easily) also how does the DJ pro suspension affect the handling of the car .
Thanks, Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 12-02-2005, 01:21 PM   #11610
Arrow setup
Edward
more droop 1.5 to 2mm is like a foam setup at 1.5 and 2 for rubber its not moving enough weight yes 1st set your camber then set the ft ride H at 5mm and 5mm droop set the rear ride H at 5.5mm 4mm droop and you will see ...7yrs OK r u on the same lap as the fast guys or the same lap times ? what kind of carpet ?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
