RC10B4.1 FT/WC
Old 03-09-2012 | 11:51 AM
  #12586
Asharus's Avatar
I think it's time to start a new thread for this topic that seems to haunt this B4.1 thread.
Asharus is offline
Old 03-09-2012 | 11:55 AM
  #12587
mxracer458's Avatar
so are the ghea pistons worth 22 bucks?did you really notice any difference?
mxracer458 is offline
Old 03-09-2012 | 12:03 PM
  #12588
Originally Posted by DaveW
You mean bound and rebound. Spring RATE is controlled by wire thickness ONLY.
This is partially true. In coiled compression springs, like the one in our rc cars, spring rate is NOT determined/controlled by wire thickness ONLY. The wire diameter, the diameter of the coil/spring itself, and the number of coils are all taken into account in overall design of the spring.
elnitro is offline
Old 03-09-2012 | 12:19 PM
  #12589
Why are a lot of people fixated on the springs lately? Orange front that, pink rear that, $20 Kyosho this, Durango that, LOL. If you are as good the the factory drivers, taking the same line everytime, keeping the lap times the same or a few tenths of a second from each other, then it is time to get the speed tweaks here and there. Until then, save some more money for batteries, tires, etc. Just an observation.
elnitro is offline
Old 03-09-2012 | 12:21 PM
  #12590
DaveW's Avatar
:facepalm:
Answer this then...
Does wire thickness ONLY determine the RATE of a swaybar?
If the bar is bent, does it affect the RATE of the swaybar?
You are aware that a swaybar IS a spring in itself... right?
The thickness of the wire is what applies the resistance (rate) against applied force.
The thickness of the wire is what controls RATE.
Larger coils spread the same resistance (rate) across a wider area. This is why you hear people define a BB spring feel as 'different', 'smoother', etc. A larger coiled spring (same RATE, same wire diameter) does the same job easier than a small spring. Progression is a different matter entirely.
DaveW is offline
Old 03-09-2012 | 12:22 PM
  #12591
Spring rate is controlled by wire diameter, the diameter of the spring, and the number of active coils.
turner66racing is offline
Old 03-09-2012 | 12:23 PM
  #12592
davidfast's Avatar
IMHO no
davidfast is offline
Old 03-09-2012 | 12:26 PM
  #12593
:double facepalm:
What does a swaybar has to do with anything? I thought you were talking about COILED springs, (linear, progressive, etc. etc.). You know the one in our rc cars?
Did you not read what I post, COILED SPRINGS (compression)? You are all over the place.
elnitro is offline
  #12594
DaveW's Avatar
I feel its important if the same misnomers continue to arrise. It affects the B4.1 and is directly related to the topic.
If everyone used the same definition when talking about any given subject... there would be no misinformation. Accurate information is what makes you a faster racer. How is it any different than thinking an 87t spur gear gives you more top end versus an 84t spur gear using the same pinion? Its wrong.
Sure the spur gear seems like an easy answer... but so many people STILL dont know which way to go to make the best of their setup.
DaveW is offline
Old 03-09-2012 | 12:27 PM
  #12595
DaveW's Avatar
:double facepalm:
:triplequadrupledfacepalm:
Answer the questions, and you will realize why my face hurts so bad right now...
DaveW is offline
Old 03-09-2012 | 12:32 PM
  #12596
onefast8's Avatar
Nope.
onefast8 is offline
Old 03-09-2012 | 12:33 PM
  #12597
Sigh....do what you want. I'm done here.
elnitro is offline
Old 03-09-2012 | 12:45 PM
  #12598
JEFFs SC10's Avatar
The bottom line is this : if you dont have big bore springs on your ride, you arent cool.
JEFFs SC10 is offline
Old 03-09-2012 | 12:54 PM
  #12599
Waflet's Avatar
hideeho
with out a doubt, that is the most accurate statement I have heard regarding springs during this whole discussion!
Waflet is offline
Old 03-09-2012 | 01:02 PM
  #12600
DaveW's Avatar
Maaan! :kicks dirt:
Its ok... im cool with being UNcool.
DaveW is offline
