RC10B4.1 FT/WC
Old 04-26-2012 | 01:00 PM
  #14086
rb-digi's Avatar
Originally Posted by mxracer458
I've never had one pop of on my buggy yet,but i have had two in the rear at the hub shear in half,never had that happen to me before.
man i have popped a bunch but mostly thats my fault. my stock veh i havent been havin the issue as much but i def ran into the same thing with the back ones folding/shearing after time.I just built my mod and have made a few mistakes in itside note-i saw a guy running the round grey losi ballcups on his b4.1 this weekend. I dont think the stock ball cups are too weak as i have snapped some ballstuds in half and i would rather pop a ballcup then replace u braces or whatever the snapped ballstud is in, i havent had any pop off un warranted so ill just try and clean up my mod driving..
rb-digi is offline
Old 04-26-2012 | 01:13 PM
  #14087
rb-digi's Avatar
Originally Posted by Matt Trimmings
Be careful when doing this and only using the one end of the turnbuckle to thread the ball cup as one side of the turnbuckle is left hand thread and the other is right hand thread.
thnk you.. i think i see your point here..the threads run at a angle and the reverse threads would be angled the opposite way . dont have em in my hand right now but i can imagine if i dont mind the threads direction the ones that i make a mistake will be "cross threaded" and and can strip out easier or cause more binding wich was the initial issue with the ball cups..ill do too differnt batches and keep the reverse threads pre drilled by reverse side of the turnbuckle.. maybe the mirror image is confusing me ahahah
rb-digi is offline
Old 04-26-2012 | 01:27 PM
  #14088
Waflet's Avatar
hideeho
The stock ball cups are NOT weak. every time I try shaving my rear c plate & let my 8yr old run it he breaks the c plate. he even broke one that I didnt shave! so, no, I see no problem with weak stock ball cups, as a matter of fact I would MUCH rather have had 4 ball cups pop than to have gone through 4 c plates for my son!
Waflet is offline
Old 04-26-2012 | 03:02 PM
  #14089
SpartanExec's Avatar
Just finished anodizing my turnbuckles gold
If anyone wants to know the process, I can write it out or make a video on my next batch. Many colors are possible. Purple, green, red, blue gold...
Now I just have to drive fast
Attached Thumbnails RC10B4.1 FT/WC-photo.jpg
SpartanExec is offline
Old 04-26-2012 | 03:37 PM
  #14090
mxracer458's Avatar
did you remove the blue first or just dip them in? 7 9 volts?
mxracer458 is offline
Old 04-26-2012 | 03:59 PM
  #14091
I used metal polish and put the turnbuckle in a dremel and cleaned off all the original blue, then used 12 9v batteries and dr pepper. + wire goes to turnbuckle and negative sits in the dr pepper.
7 9v works okay, but it's not a real gold look. at 108v the gold really comes out bright like in the picture I posted.
Old 04-26-2012 | 04:09 PM
  #14092
mxracer458's Avatar
No simple green just dr pepper?
Old 04-26-2012 | 04:25 PM
  #14093
Waflet's Avatar
Hideeho
Ok, I'm rediculously intrigued. You polish the blue off, dip the aluminum part in a can of DP, apply current & you end up w/ gold parts! That is awesome! I would love details &/or a video.
Waflet is offline
Old 04-26-2012 | 04:30 PM
  #14094
EvanAZ's Avatar
I'd like to do red, how would you go about doing that?
EvanAZ is offline
Old 04-26-2012 | 04:42 PM
  #14095
t0p_sh0tta's Avatar
Originally Posted by Waflet
Hideeho
Titanium.
t0p_sh0tta is offline
  #14096
madweazl's Avatar
Video to help with anodizing titanium parts.
madweazl is offline
Old 04-26-2012 | 04:48 PM
  #14097
Originally Posted by zipperfoot
I posted the info on page 869.
Here is what i used...
TLR5172 Team Losi Racing Front Shock Spring Set (2.5 Rate/Red)
TLR5166 Team Losi Racing Rear Shock Spring Set (1.8 Rate/White)
TRA3768 Traxxas Shock Spring Retainers (Upper & Lower) x2
Thanks for the info,very grateful.
IVAN RM is offline
Old 04-26-2012 | 05:23 PM
  #14098
Waflet's Avatar
Originally Posted by t0p_sh0tta
Titanium.
Hideeho
Ok, titanium. You know what I mean even if I don't
Waflet is offline
Old 04-26-2012 | 06:09 PM
  #14099
Matt Trimmings's Avatar
Originally Posted by madweazl
Wont affect the ballcup.
Keep telling yourself that...
Matt Trimmings is offline
Old 04-26-2012 | 06:24 PM
  #14100
nismomike's Avatar
+1 Thats just asking to be stripped or yanked out. But if you are very careful and dont mix them up, then it will be fine. Although, I've never had a problem with the good ole fashoned way of threading ball cups. I replace every so often whether they need it or not. Especially the rear passenger outer cup. I replace it after every 2 times I pop it off to adjust my diff.
nismomike is offline
