RC10B4.1 FT/WC
Old 11-15-2011 | 01:13 AM
  #7441
-WHEELMAN-'s Avatar
Originally Posted by 916bdogg
Factory Team Caster Blocks Amainhobbies.com ..
Those are the ones and the only reason we run them is because the outer hole on the three hole castor blocks (stock) never gets used and the stiffer plastic of the two hole castor blocks is prefered.
-WHEELMAN- is offline
Old 11-15-2011 | 06:50 AM
  #7442
brent701's Avatar
Well after reading and looking at some gearing some of you are running.
What is a good gearing setup to run?
Main track I run on is tight no large anything, lol
Average lap time is about 13.00 sec dipping into the mid to low 12's for a fast lap. Motor is a Ballistic Novak 13.5T no ESC timing can time the motor .
Right now i am sitting at 20/81 per the instructions sheet from the Buggy
but after reading all the different gearing on here I am lost
brent701 is offline
Old 11-15-2011 | 07:08 AM
  #7443
Asharus's Avatar
I used to run 75/30 when I had that motor
Asharus is offline
Old 11-15-2011 | 10:09 AM
  #7444
When I ran the Ballistic 13.5 on my B4.1 I set end bell timing up to 45* with no esc timing. I gear at 30/81. Ran great and super fast. The indoor clay track I run on is pretty big (6900sq ft)but I feel that a 17.5 with 45* end bell timing on 33/72 is plenty fast. At practice I can keep up with just about any vehicle out there. Plus after an 8min run I come off the track between 120* - 125*.
jamr1130 is offline
Old 11-15-2011 | 10:12 AM
  #7445
Here's a good gearing guide website.
http://www.rcgearhead.com/Gearing/Browse
jamr1130 is offline
Old 11-15-2011 | 10:16 AM
  #7446
Wild Cherry's Avatar
Tech Legend
Default 2 hole caster verses 3 hole caster block
The difference is not really the plastic .....
The difference is the 3 hole axle height is .030 higher than the two hole version .
What does this all mean to how the car handles ?
Three hole has smoother or less steering compared to the two hole ....*
*Comparing both with the steering block installed in the middle of the caster block...
So ? If you ran the three hole block .030 lower , it would be the same as a 2 hole in the middle ....
Wild Cherry is offline
Old 11-15-2011 | 11:09 AM
  #7447
-WHEELMAN-'s Avatar
Good info!! Really cant tell by looking at the two side by side?? At least I cant!! Thanks!!
Old 11-15-2011 | 11:29 AM
  #7448
Tech Legend
I checked it out first to make sure .
Gt-2 needs smoother steering for outdoor low traction conditions , thus the three hole was born ....
Old 11-15-2011 | 11:43 AM
  #7449
alien rc's Avatar
Excuse me this question but is there someone who can measure the wheelbase of his B4.1 with a long chassis (+8mm) ?
Thank you for your help...
alien rc is offline
Old 11-15-2011 | 11:52 AM
  #7450
Cpt.America's Avatar
you are WAY undergeared. With no ESC timing, and maybe just a little bit on the motor itself, you should be closer to 27-28/78 for a 13.5
Cpt.America is offline
Old 11-15-2011 | 12:55 PM
  #7451
brent701's Avatar
This is the track I run on mainly
http://www.youtube.com/watch?v=riCgl...&feature=feedu
brent701 is offline
Old 11-15-2011 | 01:54 PM
  #7452
http://www.youtube.com/watch?v=tY0w-...layer_embedded
Here's the my track. Current layout at last saturday's race. Looks to be about 3X the size of yours. So my gearing suggestion probably would not be good for you as you don't really need much top speed for a long straight like at my track. You need more torque to clear jumps and exit speed. May be around 26/75 or 25/72. basically a combo that will put around 7.0-7.5 final drive ratio. Hopefully others on here that run on tight tracks like yours can chime in for suggestions.
Edit: These suggestions are for 13.5.
jamr1130 is offline
Old 11-15-2011 | 02:08 PM
  #7453
joelwhite's Avatar
281mm
joelwhite is offline
Old 11-15-2011 | 02:20 PM
  #7454
916bdogg's Avatar
Anyone running the Panther slicks ,Are they any GOOD ?
916bdogg is offline
Old 11-15-2011 | 02:37 PM
  #7455
Motofan747's Avatar
Originally Posted by Motofan747
Hey guys new here to the b4.1 just coming of the 22. I was wondering what things i should try to get more steering/eliminate push out of my buggy. My setup is mostly Ryan Mailfield Reedy Race but running 35 in front 32.5 in rear with silver springs. Any suggestions would help.
? Anyone???
Motofan747 is offline
