RC10B4.1 FT/WC
Old 11-15-2011 | 02:51 PM
  #7456
YankeeFan123's Avatar
the extended chassis will give you more steering, I dont know how to eliminate push
YankeeFan123 is offline
Old 11-15-2011 | 03:07 PM
  #7457
ray_munday's Avatar
Originally Posted by Motofan747
? Anyone???
What sort of track are you running on? The Reedy race was held at a very smooth indoor track.
Are you suffering on power push? I would suggest the following:
- go to 2 limiters in front shocks
- add some weight to the front (~10g in front of servo will help) and move the battery forward
As always, most important thing is to make sure you have the correct tyres for the track before trying to change too much on the setup.
Ray
ray_munday is offline
Old 11-15-2011 | 03:22 PM
  #7458
Motofan747's Avatar
Mostly on power push. I will try those changes. I have the right tires for sure and its relatively close to the reedy race track but a little different which made me do those changes.
Motofan747 is offline
Old 11-15-2011 | 03:35 PM
  #7459
B4power's Avatar
I got a few questions about my B4
I am gonna get a diff rebuid kit for my FT B4.
I bought this buggy used a while ago and it turns out the previous ownder used black grease on everything.
In the manual it says to use diff lube on everything and to use black grease to assemble the thrust washer bearing.
Is that the correct way or is there a better way to assemble a differential?
B4power is offline
Old 11-15-2011 | 03:41 PM
  #7460
brent701's Avatar
http://www.rctech.net/forum/electric...er-clutch.html
brent701 is offline
Old 11-15-2011 | 04:07 PM
  #7461
Tim Garland's Avatar
Default gearing
hey guys what would i gear a 10.5 stock on a small in door track, i ran a 10.5 with a 22=81 with temps at 86, after 8:00 main, where do i need to gear it at???
Tim Garland is offline
Old 11-15-2011 | 04:18 PM
  #7462
Wild Cherry's Avatar
Tech Legend
24t to 26t pinion on a 81 spur , start with 24T...(B4)
Wild Cherry is offline
Old 11-15-2011 | 05:08 PM
  #7463
idrummerboy13's Avatar
wrong I am pretty sure it pushes more. Think of a bus ...vs a car.
idrummerboy13 is offline
Old 11-15-2011 | 05:11 PM
  #7464
bilster44's Avatar
Originally Posted by 916bdogg
Anyone running the Panther slicks ,Are they any GOOD ?
NO ! Slicks need closed cells in them. Panthers are TOO tall for 1/10 scale closed cells to fit properly, because of the gap between the top of the foam and the inside of the carcass. Air pockets are no bueno.
bilster44 is offline
  #7465
This. The longer the wheelbase the less steering a car will have. As for on power push, I can only suggest more forward bite.
Racer X8000 is offline
Old 11-15-2011 | 05:31 PM
  #7466
ya. 86 after a 8 min main?? thats crazy, you definitely can go to like a 26 27 and then go from there
Old 11-15-2011 | 05:37 PM
  #7467
xBRxSAIGON's Avatar
Thats what we used to run at our track when the track was kept more wet for super high traction and they worked great!
xBRxSAIGON is offline
Old 11-15-2011 | 05:58 PM
  #7468
916bdogg's Avatar
With what foam INSERT ? Thanks
916bdogg is offline
Old 11-15-2011 | 05:59 PM
  #7469
916bdogg's Avatar
your right on that cause i put a JC CLOSED CELLS IN A SET OF CLAY SWITCHES AND THEY DID NOT NOT FEEL FILLED OUT .. Hmmm
916bdogg is offline
Old 11-15-2011 | 06:04 PM
  #7470
916bdogg's Avatar
? Anyone???
try four limiters in front 32.5wt oil #2 pistons !
916bdogg is offline
