RC10B4.1 FT/WC
Old 11-14-2011, 03:03 PM
  #7426
Jake S's Avatar
Trader Rating: 67 (93%+)
Originally Posted by brent701
Why does it seem a lot of you guys are so low on the Spur and high on the pinion?
I am running a 20/81 and it has a butt load of low end.
they are doing it to get more top end out of the motor, 81/20 is what you would run on like a 6.5...
at the top level cav runs 81/22 on a 7.5.
Jake S is offline
Old 11-14-2011, 03:18 PM
  #7427
turbo toic's Avatar
Originally Posted by bilster44
DOES ANYONE EVER RUN THE FRONT CAMBER LINK ON THE OUTSIDE HOLE OF THE FRONT SHOCK TOWER AND LIKE IT?
right now im running outside front tower and outside on 2 hole 30 casters and it gave it more overall steering compared to inside on tower and inside on 3 hole 30 caster...hope that helps at all....what r u looking for
turbo toic is offline
Old 11-14-2011, 03:20 PM
  #7428
Motofan747's Avatar
Hey guys new here to the b4.1 just coming of the 22. I was wondering what things i should try to get more steering/eliminate push out of my buggy. My setup is mostly Ryan Mailfield Reedy Race but running 35 in front 32.5 in rear with silver springs. Any suggestions would help.
Motofan747 is offline
Old 11-14-2011, 03:52 PM
  #7429
Just reading this and have never asked... what are the differences between the 2 hole and 3 hole caster blocks? Is this it more steering?
Where do you buy the 2 hole all of the ones I have are 3 hole.
Thanks!
gguertin145 is offline
Old 11-14-2011, 04:22 PM
  #7430
idrummerboy13's Avatar
Trader Rating: 15 (100%+)
the post above yours will help and running less toe in the rear will also...try 2.5 block instead of 3.0 and use .5 hubs on the kit..
idrummerboy13 is offline
Old 11-14-2011, 04:48 PM
  #7431
tommy911t's Avatar
Trader Rating: 50 (100%+)
Thanks!
I keep seeing this in the setup sheets, and I'm also wondering...
Dudes?
tommy911t is offline
Old 11-14-2011, 05:20 PM
  #7432
bilster44's Avatar
Dudes?
The outer hole (closest to the front wheels) on the 3 hole blocks is what has been added. The inner two holes are the same as the old "two hole" caster blocks.
bilster44 is offline
Old 11-14-2011, 05:41 PM
  #7433
aeRayls's Avatar
The 2 holes are made of the older stiffer plastic.
aeRayls is offline
Old 11-14-2011, 06:02 PM
  #7434
flippz's Avatar
Originally Posted by flippz
would there be any reason why the thrust spring would be missing from my ball diff? i purchased the ball diff used for $15 out of a part out sell.... i threw it in my car and it has been fine. tonight i decided to take it apart and look at it, and when rebuilding i was following the instructions from the online manual and it was saying to install the spring i do not have. other than replacing it is there anything i should do or a reason for it missing? i have raced it three times and like i said it has done fine.
i know i am not a regular in this room but was wondering if some one could help with the question? i am learning with this car and mostly have ran nitro so was wondering if the spring was left out for a reason.
thanks
flippz is offline
Old 11-14-2011, 06:09 PM
  #7435
tommy911t's Avatar
Thanks for the responses to the two vs 3 hole question.
thanks
I would quadruple check that it is not still in the outdrive. Ive never heard of going springless in the diff, on or off road, but I am by no means an expert.
Maybe you just stumbled on to the super secret trick that all the pros have been trying to keep secret for so long! ...or maybe the previous owner just forgot to put it in.
Old 11-14-2011, 08:37 PM
  #7436
916bdogg's Avatar
So they would not work or will they . If I'm correct they took the three Hole Caster blocks from the T4 .
916bdogg is offline
Old 11-14-2011, 08:44 PM
  #7437
916bdogg's Avatar
Lightbulb
B4.1 or T4.1 .....
Attached Thumbnails RC10B4.1 FT/WC-asc7922_1.jpg
916bdogg is offline
Old 11-14-2011, 08:48 PM
  #7438
916bdogg's Avatar
Thumbs up
Factory Team Caster Blocks Amainhobbies.com ..
Attached Thumbnails RC10B4.1 FT/WC-asc9593_1.jpg
916bdogg is offline
Old 11-14-2011, 10:04 PM
  #7439
thanks
Those plastic t-nut wings aren't going to hold the halves together well enough for it to work without the spring...
The only other possibility is that they used a super long t-nut, like an ATD or longer, but I have no clue how you'd adjust it or keep the screw from backing out.
EricJ is offline
Old 11-14-2011, 10:05 PM
  #7440
aeRayls's Avatar
2 hole are the original ones
3 hole came out with the gt2
aeRayls is offline
