RC10B4.1 FT/WC
Old 11-14-2011, 08:42 AM
  #7411
xBRxSAIGON's Avatar
Originally Posted by TfnG
My local indoor clay track does not allow boost in any stock classes. I'm running 69/33(b4.1) and still coming off at no more that 105 degrees. Doing this with a Ballistic motor and Tekin in blinky mode.
2 weeks ago the announcer was calling me out in first round saying I prolly had it boosted...until after the round I showed him the blinks. So I'd say my setup is pretty fast.
Are you still runnin a 69/33 setup if so w/ what timing set. Also would you recommend this on med. bite indoor clay/technical layout..
xBRxSAIGON is offline
Old 11-14-2011, 08:52 AM
  #7412
Tech Legend
Wild Cherry's Avatar
Originally Posted by mjk1210
do you have Popped Cherry or perhaps Cherry Pie confused with Wild Cherry?
I got to get a new Avatar ....
Wild Cherry is offline
Old 11-14-2011, 09:40 AM
  #7413
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Sorry if this has been asked already, but do the new B4.1 kits have the updated (lengthened) chassis included? Thanks.
Rich Panganiban is offline
Old 11-14-2011, 09:44 AM
  #7414
bdyche's Avatar
No, the +8mm is still an option part.
bdyche is offline
Old 11-14-2011, 10:04 AM
  #7415
-WHEELMAN-'s Avatar
Trader Rating: 267 (98%+)
I would say closer to 72/32 for tight technical. Not sure if your talking tight or open technical??
-WHEELMAN- is offline
Old 11-14-2011, 10:06 AM
  #7416
brent701's Avatar
Trader Rating: 8 (90%+)
No. Normal chassis
brent701 is offline
Old 11-14-2011, 10:24 AM
  #7417
bilster44's Avatar
Hey guys, are there many of ya out there that are running the the shorter front camber link? If so, are you liking it?
bilster44 is offline
Old 11-14-2011, 11:06 AM
  #7418
Asharus's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Wild Cherry
Ran the Finnisher on my B4 8m for the first time last night and broke my personal best by about 5sec....
They told me it would be only slightly more aggressive compared to the Punisher.
I agree...
The 8m likes the extra steering , needs it actually and makes for a lot better performance than any other body I have use to date on the new chassis...
Don't expect a harder car to drive , the Finnisher is not darty at all .
I tell you now , get the thing for your 8m and hurry up about it ....
still using Brents set-up , except .....
back shock
drill #3 piston with a #55 & 27.5W oil , green spring
2.5 pivot block , 0 degree rear hub
Very fast ....
thx for that, which brent setup are you referring to? the old surf city classic one or the new indoor grand prix one? i'm running the surf city one and it feels like the car could use a little more rear traction
Asharus is offline
Old 11-14-2011, 12:00 PM
  #7419
idrummerboy13's Avatar
Trader Rating: 15 (100%+)
your running that to the t? shocks setup and all... I found traction was great.
Maybe its the body? I liked my jc finnisher a lot with it...
idrummerboy13 is offline
Old 11-14-2011, 12:02 PM
  #7420
Asharus's Avatar
yep, everything. finnisher as well with the hi clearance wing cut down to the top line.
my sc10 is planted, turns on a dime and rear traction is great, but not so much on my b4.1. i switched from gold barcodes to soft rebars and it helped a little, but could still use some more bite.
Asharus is offline
Old 11-14-2011, 12:06 PM
  #7421
bilster44's Avatar
I am/was referring to this one on the AE site when I was asking about the short front camber link. Proline Surf City Classic 08/28/2011. Are many/any of you guys running the shorter front link?
Old 11-14-2011, 12:32 PM
  #7422
Guest
How small of a track would u run this gearing on?? And what would I gear a tekin rs with a 10.5 stock no boost.
LOSIRACER77 is offline
Old 11-14-2011, 01:38 PM
  #7423
bilster44's Avatar
DOES ANYONE EVER RUN THE FRONT CAMBER LINK ON THE OUTSIDE HOLE OF THE FRONT SHOCK TOWER AND LIKE IT?
Old 11-14-2011, 02:16 PM
  #7424
xBRxSAIGON's Avatar
Tight Technical, right now i'm runnin 75/26 just so I dont over shoot the jumps, I have a 72/31 setup I can try. thanks
Old 11-14-2011, 02:22 PM
  #7425
brent701's Avatar
Why does it seem a lot of you guys are so low on the Spur and high on the pinion?
I am running a 20/81 and it has a butt load of low end.
brent701 is offline
