RC10B4.1 FT/WC
Old 11-09-2011 | 06:48 PM
  #7291
air8's Avatar
Ok guys. How do i need to setup the B4 hex adapters? Thick ones in front or back? If thick ones on back then the blue tapered washer is removed right?
air8 is offline
Old 11-09-2011 | 07:00 PM
  #7292
shortcut's Avatar
Does anyone still make aluminum a arms for the B4 ?
shortcut is offline
Old 11-09-2011 | 11:31 PM
  #7293
teeforb's Avatar
Question guys. I bought a ft t4.1 from someone. Most of the stuff does look FT. But other stuff isn't. Two things in mind is the shocks and rear cvd. The shocks doesn't have the bottom screw caps, but instead you have to insert the shock orings from inside the track. The rear cvd are different from the cvd I see on ft t4.1. Any clue why is this? Im thinking it was a ft t4 being converted to a t4.1.
teeforb is offline
Old 11-10-2011 | 12:24 AM
  #7294
RA99GT's Avatar
those are the v1 shocks from the t4. the t4.1 has the v2 shocks with the "cap" on the bottom. the t4 has cvd's (cup on the bone), while the t4.1 has cva's (cup on the axle).
RA99GT is offline
Old 11-10-2011 | 12:29 AM
  #7295
teeforb's Avatar
Then, yes it was a t4 and not a t4.1. What are the other differences?
teeforb is offline
Old 11-10-2011 | 01:09 AM
  #7296
Jerz616's Avatar
I just got my FT b4.1 together minus the shocks. Mine kit was missing the whole F bag. Once AE gets them to me I will be ready to go. What would be best to start with for gearing. I have a MMP and. Tekin 7.5 redline (overkill I know), it's what I had. My local track is a med sized indoor clay track. Has pretty good traction. I want to be fast but don't want to be so insanely fast that I am all over the place.
Jerz616 is offline
Old 11-10-2011 | 06:19 AM
  #7297
Lonestar's Avatar
hey ae 2wd gurus
my b4.1 keeps stripping the bukhead (bh) screw holes where the tiny dinky screws that hold the alum bh brace are... i mean, i mount a new bh, run the car a few packs, brace is wobbly and threads are stripped... and no i'm no scharzenegger when tightrening them. Yes i coul hi less stuff (although i'm not the worst....) but theres sthing funny here as this is the 2nd bh that goes to the bin now...
any clue?
thanks all
paul
Lonestar is offline
Old 11-10-2011 | 06:20 AM
  #7298
Lonestar's Avatar
typing w 1 hand (left) sorry
Lonestar is offline
Old 11-10-2011 | 06:21 AM
  #7299
Asharus's Avatar
the plastic bh sucks, i bought the FT alu bulkhead and haven't had that problem since. the plastic bh works fine on the sc10s though....
Asharus is offline
Old 11-10-2011 | 06:26 AM
  #7300
Jmuck69's Avatar
Where was the other hand??
Jmuck69 is offline
Old 11-10-2011 | 06:56 AM
  #7301
Lonestar's Avatar
i try to not use moe (expensive) alloy that needed on the car... plus my b4 never did thaT usually the beauty of ae stuff is it works out of the box just fine wthout hopups
right arm bandaged to my chest (tendinitis)
<insert cheap s3x joke here>
Lonestar is offline
Old 11-10-2011 | 07:27 AM
  #7302
Jmuck69's Avatar
That sucks!
Jmuck69 is offline
Old 11-10-2011 | 08:13 AM
  #7303
Lonestar's Avatar
That sucks!
no worries
Lonestar is offline
Old 11-10-2011 | 11:09 AM
  #7304
RCmayor's Avatar
hey ae 2wd gurus
any clue?
thanks all
paul
2 things to try. First put some thin CA in the bulkhead screw holes but don't put the screws in until the CA dries. Make sure the CA is a thin coat and doesn't fill up the hole.
Next thing is to tap them out with a 440 tap. Just don't go too far in cause the holes aren't very deep. Once the tap bottoms unscrew it then put some 440x3/8" screws in. If those ever come loose put a little CA in there like option one. Don't glue the screws in though cause when you take the screws out the plastic threads will come out with the screw.
RCmayor is offline
Old 11-10-2011 | 11:27 AM
  #7305
racer53's Avatar
http://www.ebay.com/itm/ALU-F-R-LOWE...item2eb0da50b0
racer53 is offline
