RC10B4.1 FT/WC
Old 10-18-2011 | 09:41 PM
  #6691
racer1812's Avatar
Super Moderator
My guess is they're thicker than the advertised 25mm then. I've tried several brands that are all 25mm (measured) and they all fit.
racer1812 is offline
Old 10-18-2011 | 10:30 PM
  #6692
Jake S's Avatar
Originally Posted by T-BirdJunkie
ThunderbirdJunkie just tried his GensAce 40c 5000 in his 4.1 that's been a 4.1 all its life, and it doesn't fit either.
with the 4.1 tower the gensace 40c and 50c fit perfectly in my buggy.
with the 4.1 tower i can run the battery in full forward or full rear position.
with the old b4 tower if i wanted to run the battery in the rear position it was really tight, but would work if the rear of the strap was put in first.
Jake S is offline
Old 10-18-2011 | 11:01 PM
  #6693
No problems here with Gens Ace Lipos on my FT B4.1.
jpcopeland1 is offline
Old 10-18-2011 | 11:40 PM
  #6694
I just got a FT B4, the carbon rear tower would not work with a ace gen 4000. The carbonfiber battery strap seemed like it was stressed to much. I replaced the rear tower with a reg plastic b4 tower and it works perfect now. FT thumb screws only way to go for hold downs.
Rawwolf is offline
Old 10-19-2011 | 12:05 AM
  #6695
Aoh
odd, all i run are gens ace 40c & 50c 5000 mah packs in my FT b4.1 and they fit perfect.
Aoh is offline
Old 10-19-2011 | 12:07 AM
  #6696
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
It fits fine, it just doesn't slide under the shock tower.
T-BirdJunkie is offline
Old 10-19-2011 | 12:23 AM
  #6697
Cpt.America's Avatar
I just got new Gens Ace 5000 40c batteries 2 weeks ago, and they fit my 4.1 flawlessly.
Cpt.America is offline
Old 10-19-2011 | 12:44 AM
  #6698
It may be new vs old then. This one is like 7 months old. They've done some case revisions in the past month or two.
Old 10-19-2011 | 12:56 AM
  #6699
Wild Cherry's Avatar
Tech Legend
TBird , use .030 shims under rear tower and make the extra height you need to fit the new Li-Po...
or use the 4.1 tower
Wild Cherry is offline
Old 10-19-2011 | 01:00 AM
  #6700
That's a backup battery. The batteries that are run in the car fit fine in it...and it IS a B4.1 tower :P
Old 10-19-2011 | 04:34 AM
  #6701
I was putting the rear of the strap over the tower on my B4 when using the Gen 5000. It held just fine. They fit just right in my B4.1.
Harry Sachs is offline
Old 10-19-2011 | 06:20 AM
  #6702
Leedog's Avatar
Default Is this possible?????
Hello, guys. Ive surfed back a few pages and didnt find anything on the subject. So id figured I would ask this question. I race on a offroad carpet track with my b4.1 factory team (which came with a ball diff) Is it possible as a tuning option to install a gear diff in this buggy? This carpet is tough on ball diffs. If it is possible, what parts are needed to complete this job from start to finish? New trans? Sc10 gear diff? Id really like to give it a shot but im not sure at all what parts to get. Thanks, Lee...
Leedog is offline
Old 10-19-2011 | 06:31 AM
  #6703
Kyle Wilson's Avatar
Originally Posted by Leedog
Hello, guys. Ive surfed back a few pages and didnt find anything on the subject. So id figured I would ask this question. I race on a offroad carpet track with my b4.1. Is it possible as a tuning option to install a gear diff in this buggy? This carpet is tough on ball diffs. If it is possible, what parts are needed to complete this job from start to finish? New trans? Sc10 gear diff? Id really like to give it a shot but im not sure at all what parts to get. Thanks, Lee...
SC-10 gear diff kit is all you need. Confirm that your outdrive bearings are 10mm X 16mm.
Kyle Wilson is offline
Old 10-19-2011 | 06:39 AM
  #6704
Leedog's Avatar
Wow thats it??? my existing transmission will work? Cool !!! Are there better diffs out there ?( aftermarket)
Leedog is offline
Old 10-19-2011 | 06:43 AM
  #6705
racer1812's Avatar
Super Moderator
The AE gear diff. is your only option
