Like Tree22Likes
Old 01-09-2012, 08:42 AM
  #9001
Im looking at getting a 4wd buggy. I picked up a used b44.1 ft. I havent installed the electronics yet. After reading about the dex410v3, im thinking about picking one up if i get find one. How would these compare to each other? I run on a clay indoor track. I have a lrp sxx tc v2 esc. Just need a motor and servo. I was thinking a 7.5 motor and maybe a savox 1257 or 1258 tg. Not sure which one would be better for 4wd. Thanks guys.
shark2288 is offline
Old 01-09-2012, 09:18 AM
  #9002
Trader Rating: 31 (100%+)
thats a real open ended question based mainly on opinion I will provide you some facts as i see them
1. its still primarily driver and tires that win
2. B44 is very capable
3. Durango dex410 whether v3 or not is very capable
4.B44 seem to be more fragile to me as even as recent as saturday I was again only car to finish (dex410 spec) - Bear in mind I win most of the time and dont crash much but when i do other than ball cups car has been bullitproof.
5. My car the way it is set up has been easiest to drive compared to others- I let others drive my car and they say its a cheater car )
6. I use ryan Lutz's setup -the one with 30 k front diff fluid and it is awesome
Now for my total opinion- I think the gear diffs(I rarely mess with them unlike ball diffs in all my other cars) are amazing. I think once you fix all the little things you need to address the durango is extremely capable and dependable
hope this helps
cota4rt is offline
Old 01-09-2012, 09:30 AM
  #9003
am
Here is a small video of one of our fastest drivers at theis track. This is our only indoor track on clay in Norway. We currently have -7 degrees celsius, but inly 5-10 cm of snow.
Enjoy.
http://www.youtube.com/watch?v=egzXs...layer_embedded
am is offline
Old 01-09-2012, 10:01 AM
  #9004
hope this helps
Thanks for response. It definitely seems as though the durango is more durable then the b44.1. How does the v3 compare to the 2010 spec? The spec seems to be very expensive on ebay. $600+!
Old 01-09-2012, 10:06 AM
  #9005
once again very subjective question
I am not positive all the differences but mainly big bore shocks. Personally i run indoors and i dont see the "need". Notice i said need. Refer back to point # one of driver and tires main factor for most of us.
I usually buy used cars and let someone else eat the original cost. used specs are available for $200 range with spares. I got lucky and got a perfect one for $200!!
I also have the "r" version as a backup and with a few additions of alum hinge pein holders it feels the same as the spec.
cota4rt is offline
Old 01-09-2012, 10:19 AM
  #9006
tobamiester's Avatar
Trader Rating: 359 (100%+)
Enjoy.
Nice video. Track looks like fun!!!
tobamiester is offline
Old 01-09-2012, 12:06 PM
  #9007
am
Default Durango & Axial sold to Hobbico
WOW!!!!
Check out Neobuggy!
http://www.neobuggy.net/modules/news/
am is offline
Old 01-09-2012, 12:11 PM
  #9008
dangerwr's Avatar
WOW!!!!
Check out Neobuggy!
Huh. I wonder if this is similar to how Horizon Hobby owns Losi and etc.?
dangerwr is offline
Old 01-09-2012, 12:22 PM
  #9009
jmackani's Avatar
Trader Rating: 14 (100%+)
WOW!!!!
Check out Neobuggy!
I wonder if this throws out the HRP exclusive distribution now?
jmackani is offline
Old 01-09-2012, 12:28 PM
  #9010
Trader Rating: 25 (100%+)
Originally Posted by D-A-N-4-4
Hey guys,
I'm having problems with my slipper/ spur assembly binding. It's chunky and especially when coming off of the throttle. All of the noise is coming from the spur slipper area.
The diffs are smooth when I roll it with now motor installed? So idk what's going on.
I just finished building it so everything is fresh... I've tried rebuilding it and shimming the bearing differently like 3 times.
Please help so I can drive this thing!
Still have not solved this problem...
D-A-N-4-4 is offline
Old 01-09-2012, 12:58 PM
  #9011
I'm sure it does as hobbico is the exclusive distributor for thier own brands usually. and yes it is the same as horizon/losi hobbico also has a big stake in futaba.as most futaba equipment is repaired by them.. Thats the one thing i hated i live here where both hobbico and horizon are and still couldnt get durango parts locally. now i will enjoy it hopefully being able too if they ever get parts in stock.
cm.stites is offline
Old 01-09-2012, 01:41 PM
  #9012
You gotta think so right? Don't know what it means for TD and its employees & Drivers, but maybe parts availability will be improved ?
Old 01-09-2012, 01:49 PM
  #9013
jmackani's Avatar
I was thinking about parts availability getting better also.
jmackani is offline
Old 01-09-2012, 01:57 PM
  #9014
am
I think that parts avalability problem is because Durango can not buy enough space in the production line at Kingstar.
On the other hand, maybe Kingstar do not have anymore space in their production line. They produce for quite alot of companys. If that is the case, what will happend with molds and tooling? Maybe this is why there are delays in spareparts and kits.
I am just guessing here and hope i am mistaken i both senarios.
am is offline
Old 01-09-2012, 02:05 PM
  #9015
It is quite possible that due to the nature of the logistics of companies being purchased that part production etc was put on hold to establish a price for inventory,accts receivable etc while values were established. Then possible delays due to factory scheduling and new ownership placing orders etc. REMEMBER this is pure speculation!! lol seems like one plausible explanation or part of it. Carry on
cota4rt is offline
