Like Tree22Likes
Old 01-09-2012, 03:28 PM
  #9016
rcguy48's Avatar
Hi guys do you know of a good chassis protector for dex410?
rcguy48 is offline
Old 01-09-2012, 04:43 PM
  #9017
am
Use jconseps sheets:-)
am is offline
Old 01-09-2012, 05:36 PM
  #9018
dangerwr's Avatar
Originally Posted by am
I think that parts avalability problem is because Durango can not buy enough space in the production line at Kingstar.
On the other hand, maybe Kingstar do not have anymore space in their production line. They produce for quite alot of companys. If that is the case, what will happend with molds and tooling? Maybe this is why there are delays in spareparts and kits.
I am just guessing here and hope i am mistaken i both senarios.
Originally Posted by cota4rt
It is quite possible that due to the nature of the logistics of companies being purchased that part production etc was put on hold to establish a price for inventory,accts receivable etc while values were established. Then possible delays due to factory scheduling and new ownership placing orders etc. REMEMBER this is pure speculation!! lol seems like one plausible explanation or part of it. Carry on
Sounds like you guys are thinking the same I am. Seems common for a corporation to buys these a common practice. Seems to help when you can leverage shared services and suppliers that can run the tools to make parts. Distribution and other logistical supply chain stuff can also benefit from economies of scale. We shall see! As long as Durango and Axial stay intact on the design side we should all benefit.
dangerwr is offline
Old 01-09-2012, 10:26 PM
  #9019
onekiwi's Avatar
Where can you get those from? Other places than jconcepts, whats the number
onekiwi is offline
Old 01-09-2012, 10:29 PM
  #9020
dangerwr's Avatar
Are you running a carbon chassis?
dangerwr is offline
Old 01-10-2012, 05:49 AM
  #9021
am
I have no idea were you can get the sheets.
http://www.jconcepts.net/store/index...products_id=74
am is offline
Old 01-10-2012, 06:28 AM
  #9022
jmackani's Avatar
Trader Rating: 14 (100%+)
We used to be able to buy a similar stuff used on the bottom of skateboard decks
jmackani is offline
Old 01-10-2012, 08:02 PM
  #9023
rcguy48's Avatar
No i do not have a carbon chassis why????
rcguy48 is offline
Old 01-10-2012, 08:19 PM
  #9024
dangerwr's Avatar
Grapejuice on here runs a chassis protector and do believe you want to get the right stuff or heard it can work like a big brake if you bottom out. I am just curious why some want to put a sheet of plastic on a metal chassis is all . . .
dangerwr is offline
Old 01-11-2012, 03:35 AM
  #9025
spiro's Avatar
Undertray would do the trick methinks...
http://bugleboyracing.com/index.php?productid=9
spiro is offline
Old 01-11-2012, 03:45 PM
  #9026
What other bodies fit this buggy? i know there was a kyosho body a ways back but ive heard the finisher bodies from jconcepts also fit but is it the stock b44 one or the extended.
cm.stites is offline
Old 01-11-2012, 08:21 PM
  #9027
Im going to be running a lrp 6.5 in my 410r. i have a feeling the motor is going to get super hot on a 22 pinion. those motors tend to run hot but still idk. im thinking maybe a 20? any input thankss
slumpin is offline
Old 01-11-2012, 08:36 PM
  #9028
ABBOTT's Avatar
ABBOTT is offline
Old 01-12-2012, 04:12 AM
  #9029
Bugle's Avatar
There's that Bugle Boy Racing shell
I don't think there's an extended B44 shell so it would have to be the usual one? The extension was a B4.1 thing. Having a shell that is so much wider than the car will cause a bit of parachuting going over jumps though.
Bugle is offline
Old 01-12-2012, 06:24 AM
  #9030
onekiwi's Avatar
Im no expert driver but must say I didn't really notice much difference with the FS shell and the original, I was indoors and no wind and the jumps wern't really big.
onekiwi is offline
