Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#8986
Thanks for the input and always value your knowledge. I was always under the belief that it had to be an emulsion shock. Understanding that oil is essentially an incompressible fluid and that if you were trying to compress the fluid the shock would not budge. But what I believe is that you are passing the oil through the holes in the piston. Please correct me if I am wrong.
And how can I be certain if the hubs need to be opposte from convention? I will look again on the TD website and see if they make any mention of the error. Cheers!
#8987
No worries. On the shocks what you're saying is true since there are holes. But the speed at which you could compress the shock with the little holes is SUPER slow. You can try it on a shock to see my point. Fill it up to the top, dome it on the body try not to spill, Screw on the cap. Now compress the shock all the way and you sill see that the shaft will not go all the way in. .It will hydro-lock near the top. This is what I've seen cause a lot of rear bulkhead issues in regard to breaking them. This also leads to premature leakage and a bouncy car.
If you put a hinge pint into the hub and set the face of the hub onto a flat surface like a setup board you can see which side of the hinge pin is lower. This "lower" side should face to the rear looking at the hubs from the top. Kinda confusing but give it a go.
#8988
i was able to get the 410 v3 kit today!!!
i looked every where online and could not find one in stock, but as a last ditch effort i called a hobby shop that is an hour away from my home and they had one in stock. talk about lucking out lol. ill post some pics when im done building it.
#8989
just posted up in the for sale thread selling all my tires that i dont need since i recently got a sponsor ship from panther for the dex410 and desc410r here is the link http://www.rctech.net/forum/r-c-item...l#post10134601 $15 a set shipped new and lightly used
#8990
I am pretty sure I get it. The hinge pin will slope downward once installed in the hub and placed on a flat surface. The lower side should point to the rear of the car. Effectively this reclines the hub back 1 degree, correct? They should call the reclined hubs instead?
#8991
If you do this with the V3 1 degree hubs, you only end up with 2 degrees of rear toe-in total. I tried running this way and it was way too loose. Of course the manual only shows the 0 degree hubs which they do not supply in the kit either to fit the new larger bearings..
#8994
Unlike the desc, the v3 1 degree hubs included with my kit are not +1 degree in their normal left and right hand positions. They are -1 really when you check the overall measurement since the rear is using negative toe.
#8995
can i use the rear tires from my 210 on the rear of the 410? i know they both have 14mm hexes, but are the rims and tires the same size.
thanks,
Dan
thanks,
Dan
#8997
Hey guys,
I'm having problems with my slipper/ spur assembly binding. It's chunky and especially when coming off of the throttle. All of the noise is coming from the spur slipper area.
The diffs are smooth when I roll it with now motor installed? So idk what's going on.
I just finished building it so everything is fresh... I've tried rebuilding it and shimming the bearing differently like 3 times.
Please help so I can drive this thing!
#8998
Hi.
I have used a couple of hours now to find what shock pistons pros are using when running on semi low grip tarcks with the V3 BB shocks. Cant seem to find out what to use..
Can anyone help?
Can anyone help?
#8999
It is clay, bur the "problem" is that i has some sort of "glass" surface on top.. It was suppose to be just blue clay but thay have mixed something in it. They did to get better grip, but it was not extreamly sucsessfull..
JConsepts barcodes in blue compound is ok, but not alot of grip. This is our handout tire, so this is what we use.
